ahmedmian Posted October 20, 2009 Posted October 20, 2009 Hello. How do I create a Reflected Ceiling Plan in AutoCad 2007. Do I need to use a Hatch Tool or is there a specific command for Ceiling Grids. Thanks Quote
ahmedmian Posted October 20, 2009 Author Posted October 20, 2009 Hello. How do I create a Reflected Ceiling Plan in AutoCad 2007. Do I need to use a Hatch Tool or is there a specific command for Ceiling Grids. Thanks Quote
olicanauk Posted October 20, 2009 Posted October 20, 2009 A reflected ceiling plan is everthing that is contained within the ceiling. Usually it is just created with lines on the correct layer at 600 x 600mm. Quote
Ollie8974 Posted October 20, 2009 Posted October 20, 2009 Make a copy of the floor plan. Save it as Reflected ceiling plan, then clear all objects except the walls. Then lay out the ceiling grid an install all the fixtures. Quote
rkent Posted October 20, 2009 Posted October 20, 2009 Hello. How do I create a Reflected Ceiling Plan in AutoCad 2007. Do I need to use a Hatch Tool or is there a specific command for Ceiling Grids.Thanks Hatch file attached (from Cadalyst.com) for 2'x4' grid with 1" track. This is not a zip file, simply rename it to 2x4.pat. Otherwise use hatch and if the distance is the same for x-y direction you only need to hatch once. If different sizes use two hatches, 90 degrees to one another. Quote
