In the attached drawing there is a little sketch of a 3 tank hot water storage system (minus several components so i could make the 250 kb restriction).
In the drawing, when i switch to planview, all of the pipes above a certain elevation do not show up.
I assume there's some setting on my pipe material that's keeping them from showing up in planview when above something or another, but i can't figure out what it is, or where that setting is.
Thanks for any ideas, I'm sure this is some really simple thing that i'm not seeing.
~TBL
water storage hot.dwg
