New tools for Autodesk Revit Sub customers!
http://autodesk-revit.blogspot.com/
Additional shortcut commands
A UI to control the shortcuts (hooray) no more text file editing
Conditional formatting in all products
DWG export improvements
Text formatting – from shortcuts
Find and replace text
Model lines to Detail lines and back
Link file improvements
API improvements
Autodesk Revit Model Review
Revit DBlink
Image modeler will now be included so you can create point cloud data from images and export this to DWG and import this into Revit
Wood Wall Framing tool
Finally, all the Revit Structure feature will now be included to in Revit Architecture!!! :-) Hooray!!!!
Curved beams
Beam copping
Create Trusses
Tag beam systems
Slab directions and decking
Slanted columns
Split with Gap
