I am getting this Fatal Error: Unhandled e06d7363h Exception at 7c812aebh
in auto cad 2008 when I run E Transmit command any ideas.
Cheers
Dylan
Report details:
This error report includes the following:
* Operating System name and version
* Product name and version
* Graphics configuration driver name and version
* Applications that were loaded when the error occurred
* Active command when the error occurred
* Computer name (if enabled via the Deployment Wizard or the CAD Manager Control utility)
NOTE: Even if you don't provide your contact information, it may be present in your error files.
While this information could be used to determine your identity, Autodesk will not use it for this
purpose.
Autodesk uses the data contained in the error report only to troubleshoot this problem. The error
report is transmitted over a secure connection and is not used for marketing activities. For a
complete description of Autodesk's privacy policy, click the privacy hyperlink below.
I have already done recover, audit, purge, and saved it but still crashed when I only want to do is e transmit.
any ideas
thanks
  • 1 month later...
I am using Autodesk Inventor Suite 2009 and strongly utilize the AutoCAD protion of the suite. I am working with a 3D drawing that constantly crashes out with this error. I have run multiple purge & audits, detached all xref's, wblocked to new file, basically tried everything I can think of based on over 18 year's experience using AutoCAD and just can't figure this one out.
Has anybody else out there come up with a solution?
I'd like to hear from you.
Thanks.:cry:
