Application surface color
Greetings!
How to set up the default application surface color? I looked through help but could not find the answer! :? :x
In your part templates go to the document settings for the IPT and change the Default Material to something other than default like Mild Steel. If you only wish the color to be different go to the styles and standards editor and change the coloring of the default material.
I'm asking about the colour of surfaces. If you right click a surface and go into Properties, there are two choices besides specific colours - As default and As application surface color. I could not find where to change the latter setting. Maybe it cannot be changed?
