bsplayer Posted July 22, 2008 Posted July 22, 2008 Hello, i had problem how to design a wire rope using an Autocad? :unsure: Currently i'm using autocad 2008 for completed my final thesis. i'm allways try to search the technic but never found yet.:shock: Please help me if anybody know how to make it...:cry: Quote
CADTutor Posted July 22, 2008 Posted July 22, 2008 Although this is technically possible with AutoCAD - use the Helix command to create a series of paths and then extrude circles - it's not a tool I would use for this. 3ds Max may be a better option. I guess it depends how much detail you need and what it should look like. Quote
fuccaro Posted July 23, 2008 Posted July 23, 2008 If it is a straight rope draw a helix and extrude a circle along it. Use a POLAR ARRAY to multiply it. Quote
beauXjames Posted July 25, 2008 Posted July 25, 2008 Interesting problem...as maybe the previous suggestions could get the rope to 'look' appropriate, if you're doing something for a technical project and are hoping to fully simulate this entity, i would suggest using some forumlas to drive it...what kind of thesis are you working on and what in the world does it have to do with a wire rope? Quote
avieira Posted April 26, 2009 Posted April 26, 2009 If it is a straight rope draw a helix and extrude a circle along it. Use a POLAR ARRAY to multiply it. I am having the same problema here... could someone tell me how to do the HELIX ? Quote
fuccaro Posted April 27, 2009 Posted April 27, 2009 Did you search the forum for the word HELIX? See here: http://www.cadtutor.net/forum/showthread.php?t=1396 or here: http://www.cadtutor.net/forum/showthread.php?t=78&highlight=helix or even here: http://www.cadtutor.net/forum/showthread.php?t=1186&highlight=helix or... or search yourself -there are plenty of Quote
