MartaZ Posted October 25, 2009 Posted October 25, 2009 Hi, I am trying to change a scale of the drawing. I use SCALE icon in AutoCAD 2008. It changes a scale, however changes coordinates as well. I want Z to have the same height. For example: Point A coordinates X = 575348.4593 Y = 154120.5144 Z = 34.8031 After changing a scale (scale factor=2): X = 575305.9212 Y = 154124.8346 Z = 38.5552 Is it possible not to change Z? and have it as 34.8031? Thanks, Marta Quote
MartaZ Posted October 25, 2009 Author Posted October 25, 2009 It is a topographical survey plan of a quarry. Quote
ReMark Posted October 25, 2009 Posted October 25, 2009 What exactly were you scaling and what did you use as the basepoint? Quote
MartaZ Posted October 25, 2009 Author Posted October 25, 2009 I was scaling a whole drawing. I tried to use different basepoints each time to check the difference. So it was a middle point of the drawing, as well as my point A. It always changes X,Y and Z. When you use SCALE icon and type in: 2,2,0 (for X,Y,Z respectively) it changes Z anyway. The same if you type just 2. Is there any other way to scale a drawing in AutoCAD? Quote
lpseifert Posted October 25, 2009 Posted October 25, 2009 Have a look here... http://www.xanadu.cz/en/download.asp?file=ScaleXYZ You can use the utility to rescale the Z coordinates back to what you need. I think it creates a block and changes the XYZ scales; it may explode the entities. Quote
MartaZ Posted October 25, 2009 Author Posted October 25, 2009 Thanks for that. I will have a look Quote
eldon Posted October 26, 2009 Posted October 26, 2009 SCALE always used to be for enlarging or reducing selected objects proportionally in the X,Y,and Zdirections. So only one scaling allowed. If things have changed so that you are allowed to scale differently, then the factor to be entered is 2,2,1 if you want the Z to stay the same. The old way is to make a block, then insert it with required separate X, Y & Z scaling. Quote
