pura vida Posted July 22, 2008 Posted July 22, 2008 howdy all as the title says i am using ldd 2005 and am having a minor issue with site tables. under the pull down menu Terrain, Volume Report, you can select Site Table to produce a table of all volumes created from different stratum's. the issue i am having is eliminating or deleting reported volumes from the table. where can i delete the information that tells LDD what to report when the site table is created? even if all stratum's, surfaces, volumes, point groups, etc, have been deleted from the project the site table will still report all volumes sense the project was created. any suggestions? Thanks pv Quote
rustysilo Posted July 23, 2008 Posted July 23, 2008 Check in the site manager and see if you can remove these old items you do not want to include. http://discussion.autodesk.com/thread.jspa?messageID=5938586 Quote
pura vida Posted July 28, 2008 Author Posted July 28, 2008 thanks, but that isn't is. it is not the actual site i need to delete. it is the reported volumes in the site table that i need to delete. thanks Quote
rustysilo Posted July 28, 2008 Posted July 28, 2008 I've been fishin around and the only thing I can think of trying is to check the box in your output settings that says "overwrite file" and see if that changes anything. I don't think it will, but I really am not sure at this point. I don't dabble much in Land anymore... Quote
pura vida Posted July 29, 2008 Author Posted July 29, 2008 well thanks for the effort anyway. i think i might just make a new site. that would at least start the site table over. thanks again. pv Quote
Cadco Posted March 19, 2010 Posted March 19, 2010 howdy all as the title says i am using ldd 2005 and am having a minor issue with site tables. under the pull down menu Terrain, Volume Report, you can select Site Table to produce a table of all volumes created from different stratum's. the issue i am having is eliminating or deleting reported volumes from the table. where can i delete the information that tells LDD what to report when the site table is created? even if all stratum's, surfaces, volumes, point groups, etc, have been deleted from the project the site table will still report all volumes sense the project was created. any suggestions? Thanks pv Howdy? You must be from the Southwest. Well the first thing you need to do is delete all the volume data from the DTM. Secondly, go to the Site manager and delete the site definition right after you import the definition. You can use the import later to redefine it. Now here's the trick you must attempt running a report. You should receive a small alert box informing you there's no data because there's no definition. At that point you're clear. You see the volume data is hard coded in the definition. In fact, you could have spared your surfaces and point groups my friend. Happy modeling. Quote
Cadco Posted March 19, 2010 Posted March 19, 2010 howdy all as the title says i am using ldd 2005 and am having a minor issue with site tables. under the pull down menu Terrain, Volume Report, you can select Site Table to produce a table of all volumes created from different stratum's. the issue i am having is eliminating or deleting reported volumes from the table. where can i delete the information that tells LDD what to report when the site table is created? even if all stratum's, surfaces, volumes, point groups, etc, have been deleted from the project the site table will still report all volumes sense the project was created. any suggestions? Thanks pv Howdy? You must be from the Southwest. Well the first thing you need to do is delete all the volume data from the DTM. Secondly, go to the Site manager and delete the site definition right after you import the definition. You can use the import later to redefine it. Now here's the trick you must attempt running a report. You should receive a small alert box informing you there's no data because there's no definition. At that point you're clear. You see the volume data is hard coded in the definition. In fact, you could have spared your surfaces and point groups my friend. You need to hang with knowlegable designers. I've been around all of Autodesks vertical products for years. Happy modeling. Quote
