Hello!
AutoCAD LT 2002 not working properly. Opens the DWG file, but in case of any change in the file shows the following error:
Unhandled Access Violation Reading 0x401983c Exception at 6544bab7h
If I give Administrator or Power User rights to user it works fine, but it has to remain a simple user.
Any suggestion would be appreciated
Try using the Recover command instead of Open. Does AutoCAD still crash?
What OS is being used?
Is this a networked computer?
A couple of other questions come to mind.
When did the problem first occur?
What is the source of the drawings?
Does this happen with just a select few drawings or any drawing that you open?
