gazzalp Posted October 29, 2009 Posted October 29, 2009 I have been recieving architecturals from a firm who use xclips for their plans. What we need to do is explode their drawings so we can make them a really light colour and draw over the top. The problem here is that when we explode their drawings, everything outside the xclip appears. Is there a way to select all blocks in a drawing, and delete everything thats outside the xclip? Ive read that i can use the xclipframe command, but all that does is put a rectangle around the xclip. Supposedly i can use that to trim anything outside the xclip. However with these drawings there are about 30 xclips. I dont want to have to spend 10 minutes selecting them all and doing this. Is there any way to just keep the information contained within the xclip? Thanks Quote
gazzalp Posted November 19, 2009 Author Posted November 19, 2009 anyone have any idea how to do this? Quote
alanjt Posted November 19, 2009 Posted November 19, 2009 Why not just change the color the the xref layers? Quote
gazzalp Posted November 23, 2009 Author Posted November 23, 2009 The reason i can't just change the colour is because most of the drawing are blocks, and the colour wont change without exploding. This is where the problem is created... Trust me ive tried everything amd the only way i can think of it working is to have some way that the items outside of the xclip boundary can be deleted. Quote
VVA Posted November 24, 2009 Posted November 24, 2009 I have been recieving architecturals from a firm who use xclips for their plans. What we need to do is explode their drawings so we can make them a really light colour and draw over the top. The problem here is that when we explode their drawings, everything outside the xclip appears. Is there a way to select all blocks in a drawing, and delete everything thats outside the xclip? Ive read that i can use the xclipframe command, but all that does is put a rectangle around the xclip. Supposedly i can use that to trim anything outside the xclip. However with these drawings there are about 30 xclips. I dont want to have to spend 10 minutes selecting them all and doing this. Is there any way to just keep the information contained within the xclip? Thanks 1. Restore xlip contour (polyline) 2. Explode blocks 3. Use Express tools EXTRIM command or CookieCutter2 - more fun with ET extrim Quote
The Buzzard Posted November 24, 2009 Posted November 24, 2009 I have been recieving architecturals from a firm who use xclips for their plans. What we need to do is explode their drawings so we can make them a really light colour and draw over the top. The problem here is that when we explode their drawings, everything outside the xclip appears. Is there a way to select all blocks in a drawing, and delete everything thats outside the xclip? Ive read that i can use the xclipframe command, but all that does is put a rectangle around the xclip. Supposedly i can use that to trim anything outside the xclip. However with these drawings there are about 30 xclips. I dont want to have to spend 10 minutes selecting them all and doing this. Is there any way to just keep the information contained within the xclip? Thanks In your dropdown menu under modify is the SETBYLAYER command or called out in the menu as Change to bylayer will change blocks and other entities to bylayer without the need to explode. It is the third one down in the menu. Quote
wizman Posted November 29, 2009 Posted November 29, 2009 I would do it like what buzzard suggested but if you want to try this: Wmfout the xclipped block then Wmfin it on a new drawing then explode it, you'll get entities within xclip's frame. You can take care of the scaling. Quote
DVDM Posted August 5, 2010 Posted August 5, 2010 I just ran into the same issue, and found the following utility: http://www.jtbworld.com/XClipClean.htm Quote
