Someone has probably asked this before but I can't quite make sense of the ssget function with all its options.
I want to write into my lisp a command to select a block at the end of my line which is variable pt2. I will then move the block to a new position (where the end of the line ends up).
Thanks in advance
Hi, If you are just wanting to select one object at one point have a look at the nentselp function in the developer help.
Let me know if you want further assistance.
I remember trying the ssget function for a point, though this may be wrong if someone can correct me.
(setq Ent (car(entsel))
    ss (ssget "_X" (list (-4 . "=[color=Red]1,1,1[/color]") (assoc 11 (entget Ent)))))
Cont.
Or maybe this?
(setq pt2 (getpoint)
     ss (ssget "_X" (list '(-4 . "=,=,=")([color=Navy]cons 11[/color] [color=Red]pt2[/color]))))
Blue is the dxf code, red is the co-ordinate.
Or if you wanted to add a fuzz factor:
     fuz 1.0
     ss (ssget "_X" (list '(-4 . "<,<,<")(cons 11 (list (+ (car pt2) fuz)
                                                        (+ (cadr pt2) fuz)
                                                        (+ (caddr pt2) fuz)
                           '(-4 . ">,>,>")(cons 11 (list (- (car pt2) fuz)
                                                        (- (cadr pt2) fuz)
                                                        (- (caddr pt2) fuz)
I was thinking something like;
(ssget Pt)
but that selects a single object, may pick line instead of block.
You may need to define a crossing window second point "p2" close by Pt1, then;
(ssget "c" (list pt1 pt2) '((0 . "BLOCK")))
Cont.
Or maybe this?
     ss (ssget "_X" (list '(-4 . "=,=,=")([color=navy]cons 11[/color] [color=red]pt2[/color]))))
Hey thanks Steve, your reply gave me enough to get sorted. I couldn't get the structure right for the code and kept getting errors. Such a relief when someone gives you the right info! Cheers!:D
This was my final line I inserted
 (setq ins (ssget "_X" (list '(-4 . "=,=,=")(cons 10 pt2)(cons 0 "insert"))))
I tried your your above one but as the coordinates were the same for the end of the line (cons 11 instead of cons 10).. all of the lines changed but I might actually use this somewhere else.. so adding the filter "insert" made sure there was no confusion with the command (I think :unsure:)
Thanks again
Great! glad it worked for you :) I wouldn't be surprised if there's a better way of presenting it that I'm not aware of.
CarlB, I wasn't aware of that way of using ssget on a point, thanks.
