MarcoW Posted November 2, 2009 Share Posted November 2, 2009 I searched before but can't find the solution. See the image for the problem. What I have done is to copy a *.shx file and renamed it to deltalt.shx. That did not work... Anyone with a solution to prevent AutoCad 2007 from giving this error? (I know it's not an error ...) Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 2, 2009 Share Posted November 2, 2009 Try option #2 as mentioned here. Maybe it will work. http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2898008&linkID=9240617 Quote Link to comment Share on other sites More sharing options...
MarcoW Posted November 2, 2009 Author Share Posted November 2, 2009 Hi Remark, Yes it worked! Thank you for the reply. I remember being to that section before but did not get result... Maybe I did something wrong somehow... But I will give the other machines over here the same alternative font. Thanks again. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 2, 2009 Share Posted November 2, 2009 MarcoW: It was just a lucky guess on my part. Although I've probably recommended the fix a half-dozen times I always have to rack my mind finding it. Glad it worked. Quote Link to comment Share on other sites More sharing options...
MarcoW Posted November 2, 2009 Author Share Posted November 2, 2009 %$%#^... I have tried another drawing wich has the deltalt.shx message.... Allthough it worked in the first drawing, this drawing keeps asking for the desired file. I checked the fontalt sysvariable, it is set to isocp.shx. What is going on? Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 2, 2009 Share Posted November 2, 2009 Isolated (different) fonts are not be recognized in separate drawings? Quote Link to comment Share on other sites More sharing options...
MarcoW Posted November 2, 2009 Author Share Posted November 2, 2009 I do not know what you mean... Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 3, 2009 Share Posted November 3, 2009 It appears that in two different drawings you're seeing the same error message with two different fonts. Right? Quote Link to comment Share on other sites More sharing options...
MarcoW Posted November 5, 2009 Author Share Posted November 5, 2009 No, the same font... Sorry for late reaction, kinda busy nowadaus with projects. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 5, 2009 Share Posted November 5, 2009 Gotcha. Same font appears to be missing in both drawings. What is the source of the drawing? Quote Link to comment Share on other sites More sharing options...
MarcoW Posted November 6, 2009 Author Share Posted November 6, 2009 With source you mean who created the drawing? An architect. Or do you mean what program, I don't know. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 6, 2009 Share Posted November 6, 2009 You got the drawing from an architect. Fine. Now call him up and ask him to email you the font. I'm assuming he used an AutoDesk product. Is that correct? If you don't know then find out. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted November 6, 2009 Share Posted November 6, 2009 Anyone with a solution to prevent AutoCad 2007 from giving this error? (I know it's not an error ...) This is NOT an error. AutoCAD is prompting you for a missing SHAPE file (see the title of the dialog), not a FONT file. Big difference. What I have done is to copy a *.shx file and renamed it to deltalt.shx. That did not work... Right, because again, it's looking for a SHAPE file, not a FONT file. You need to either remove the reference to the shape file, or obtain the correct shape file. Technically, you can use any shape file as long as it has the same name, but the risk in doing so is that you may end up with the wrong shapes displaying in your drawing -or- if the shape file you choose does not include the shapes required, then you will get command line errors. More info on missing SHAPE files: http://cadpanacea.com/node/27 BTW: You will only get prompted for a missing FONT file if the font cannot be found, AND if FONTALT is not set, and then the dialog will look like the one below (it will not be a standard file selection dialog): Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted November 6, 2009 Share Posted November 6, 2009 Try option #2 as mentioned here. Maybe it will work. http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2898008&linkID=9240617 See my post above. It's not looking for a missing FONT file, it's looking for a missing SHAPE file. Quote Link to comment Share on other sites More sharing options...
