can a bolck have a multiple choise attribute or is there away or creating the effect of them?
i have block for road marking with 8 attributes and was woundering if there was away of having a drop down option or somethin for some of the information
for example the line colour can only be white or yellow so have a drop down option for this insted of a text input
any ideas??
did think about having visibility actions in the block but would need about 4-5 option drop downs and you can only have one visibilty action
so didnt knwo if anyone could think of another way??
Good point, sounds like a little programming is going to be needed.
if your visibility list gets to long try linking them to lookup tables i have done this in the past - this gives you multiple pull downs.
Other than that as Alan says........ :D
Interesting, would you be willing to post an example? I'm rather curious.
yeah sure... see attached, the same principle could be applied.
SFS.dwg
