Hi,
Part of my job involves me drawing roofs. I sometimes need to squash or stretch these 2-D drawings to show the roof from diferent angles.
More simply - I have a 2D drawing made up for simple lines, rectangles and circles which I would like to squash or stretch along one plane. Not along both x- and y-axes.
Any ideas?
Thanks!
Ben
Have you looked at using dynamic blocks? Look at using the stretch parameter
or a standard block and use the properties palette to vary the X & Y scales.
Yes! dbroada. Adjusting the scales on the block properties worked a treat. That is going to save me so much time. I was stretching each individual object and its location...
I will have also have a look at dynamic blocks.
Thanks guys.
If you are still using AutoCAD 2000 then you will not have the Dynamic Block feature. This was added later.
A couple of other options- you could use MSTRETCH, or you could select multiple grips holding down while selecting them.
However, I have no idea as to when these options were introduced?
