MarcoW Posted November 5, 2009 Posted November 5, 2009 Hi, I have an xref (*.dwg) attached to my (empty) drawing. For some reason the xref's size is 19Mb. The xref itself is not very different then other drawings, strange... There are no links or attachements made in the xref. No images, no nothing special. Looks like a plain and simple drawing. I guess there are elements in the xref drawing that causes this. Maybe hatches or so... Is there a way to retrieve what causes the drawing to be that big? Pleas help, thank you in advance. Quote
chelsea1307 Posted November 5, 2009 Posted November 5, 2009 have you audited and purged and - purged the xref? Quote
MarcoW Posted November 6, 2009 Author Posted November 6, 2009 Well of courseI have, that would be the first to do. I know for shure that some entities, hatches or fonts cause this problem but how to solve? Quote
ReMark Posted August 9, 2010 Posted August 9, 2010 Are a large number of scales used? Look at the scale list. Did you purge Regapps? Quote
nukecad Posted August 9, 2010 Posted August 9, 2010 Does 2008 purge layer filters? Layer filters can get copied all over the place even when you dont want them to, you can end up with hundreds of them bloating your drawing size and older versions of acad wont purge them. Superpurge will get rid of them if you have it. If not then you have to go to FORMAT > LAYER ; drop down the list of named layer filters and delete them on by one. (Pick the first in the list, click on delete, put a weight on the enter key and go and make a coffee). Quote
ReMark Posted August 9, 2010 Posted August 9, 2010 A shareware version of SuperPurge can be download from here... http://www.manusoft.com/software/superpurge.html Quote
bensoy Posted August 9, 2010 Posted August 9, 2010 thanks. ReMark and nukecad. i do have same problems with huge xrefs. In which i will not sacrifice the good details on the xrefs. Quote
MarcoW Posted September 8, 2010 Author Posted September 8, 2010 I noticed that I never answered this thread, not my style so I would like to tell how this was solved. (Or at least how I think it was solved.) The first solution is here. What might have added to the solution is that I have copied all into a new *.dwg and saved it (replaced the original). Guess the original *.dwg was corrupted somehow. Quote
designerstuart Posted September 8, 2010 Posted September 8, 2010 the solution you mention regards scale lists becomming hugely long. at my work we have a "scale_list_cleanup.exe" program which is excellent as you navigate to a folder, select the drawings, say which scales you want them to have and it will clean them all up in one go, and prints a report of sucess. there is even an option to include xrefs in the cleanup. because i don't know where it comes from, i have not attached the files. if people want it, and a moderator says it's okay to do so, i could put it up. it really is useful! Quote
