Just wondering if anyone has encountered any problems running AutoCAD 2010 on MS XP Pro 64-Bit?
Thanks!
Why would there be any problems? Did you hear something you'd like to share with your fellow forum members?
I'm running Acad 2010 on XP Pro 64 bit. The only real problem I've had was in locating printer drivers. Also, there is no "Civil" object enabler for 64 bit Autocad. Only 32 bit. So that's a problem. But otherwise, the program runs fine.
