Nick-H- Posted November 6, 2009 Posted November 6, 2009 One of my xrefs keeps coming in about 10x smaller than it should, and i dont know why. all the other xrefs are ok Quote
skipsophrenic Posted November 6, 2009 Posted November 6, 2009 When you insert the x-ref what scale do you ask for? Is the x-ref drawn to the correct size? You could also try inserting it at a x10 scale. Quote
Nick-H- Posted November 6, 2009 Author Posted November 6, 2009 When you insert the x-ref what scale do you ask for? Is the x-ref drawn to the correct size? You could also try inserting it at a x10 scale. SCALES IS 1.0 1.0 1.0 and the xref is drawn to correct size but comes in wrong Quote
skipsophrenic Posted November 6, 2009 Posted November 6, 2009 When you bring it in try setting uniform scale, and putting 10 instead of 1 as a workaround for now, not sure what else to suggest. Quote
Tiger Posted November 6, 2009 Posted November 6, 2009 Check what Units is set in the drawing. Also the variables INSUNITS...though now that I think about it, they might be the same... Quote
Dipali Posted November 6, 2009 Posted November 6, 2009 Tools>options>user Preferrence>insertion Scale & Specify Appropriate Unit For Source Drawing & Target Drawing & It Should Work. Quote
Nick-H- Posted November 9, 2009 Author Posted November 9, 2009 Tools>options>user Preferrence>insertion Scale & Specify Appropriate Unit For Source Drawing & Target Drawing & It Should Work. its set mm Quote
Nick-H- Posted November 9, 2009 Author Posted November 9, 2009 how do i change the block unit factor Quote
Nick-H- Posted November 11, 2009 Author Posted November 11, 2009 Anyone help me? how do i change the scale factor? Quote
Dipali Posted November 11, 2009 Posted November 11, 2009 the scale factor can be changed in property winodw but i am not sure that is what you need. chneck insunits value also in host & xref drawing both or eloborate more about your problem & we can sugest sumthing else. Quote
Nick-H- Posted November 12, 2009 Author Posted November 12, 2009 the scale factor can be changed in property winodw but i am not sure that is what you need. chneck insunits value also in host & xref drawing both or eloborate more about your problem & we can sugest sumthing else. Where are the insunits? Quote
Nick-H- Posted November 12, 2009 Author Posted November 12, 2009 The scale factor is 0.0394, but i cant change it Quote
Dipali Posted November 12, 2009 Posted November 12, 2009 type insunits at the command prompt & than press F1 to understnad the values..... Quote
