is there an ACAD.PGP file in 2010 and if so WHERE?
I can't find it to save my life.....:sweat:
2009 had an edit feature right in the pull down....
type the below into the commandline; and it should reveal the location of acad.pgp:
(findfile "acad.pgp")
THANK YOU!
In the Ribbon, Manage, Customization, Edit Aliases.
Other wise if the menu is showing, it is still under Tools, Customize, Edit Program Parameters.
Two different names, way to go Autodesk.
...and if you don't really care where it is, you just want to open and edit the file, you can do this.... :wink:
(startapp "notepad" (findfile "Acad.pgp"))
having a real hard time finding my way around 2010
thanksrk... once I found it I just put it on my desktop
Wait, you mean you moved the acad.pgp to your desktop? I am not too sure that will work unless AutoCAD can find the file in its search paths. No need to move it when it is two or three clicks away from editing from AutoCAD's menu / Ribbon.
sorry about that, I meant I just created a short cut. I do that with comonly used files...
