Hi
I am trying make something similar to the GATTE command except more user friendly - ie with a small dialog box. I can return a value from the dialog box with a new text string but how do I go the next step to change the attributed tag globally?
Thanks for any help
(defun c:Gattes (/ blk tag val tg bn )
 (vl-load-com)
 (setq ESel (nentsel "\nSelect attribuite tag: "))
  (setq TextString(cdr (assoc 1 (entget (car ESel)))));existing text string
 (GattesDCL);activate dialob box
  (setq EL (entget (car ESel)));Entity list
 (setq bn (cdr (assoc 2 EL)));block name
(defun Get_DLG (/  )
        (setq TextString (get_tile "TextString"))
        (done_dialog 1)
        );defun
        (defun GattesDCL ( /  DLGID  )
        (setq DLGID (load_dialog "Gattes.dcl"))
        (if (new_dialog "Gattes" DLGID)
        (set_tile "TextString" TextString);
        (action_tile "accept" "(Get_DLG)")
        (action_tile "cancel" "(done_dialog 0)")
        (start_dialog)
        (unload_dialog DLGID)
        );progn
        (princ "\nNo DCL");the dialog box was not found
        );if
        );defun
//dcl
dcl_settings : default_dcl_settings { audit_level = 3; }
Gattes : dialog {
   label = "Global attribute Edit";
   : boxed_column {
   label = "" ;
   fixed_width = true ;
   : row {
   : column {
   : text {
   label = "Text String";
   }//column
   : column {
   : edit_box {
   key = "TextString";
   width = 30;
   }//column
   }//row
   spacer_1;
   }//boxed column
   errtile;
   ok_cancel;
   }//dialog
SSGet all matching blocks and iterate through them.
Thanks
I was looking at Lee mac's EdAtt.lsp, and this seems to be just what I want.
So why reinvent the wheel? Its very clever.........
