quizman Posted November 12, 2009 Posted November 12, 2009 I am new to AutoCad and I am using AutoCad 2009. Is there a tutorial or step by step method to create a 0 - 16 bar pressure gauge with major ticks at 1 bar intervals and minor ticks at 0.1 bar intervals. Also it will require a pointer at 0.1 bar intervals. I need to make 160 different images with the pointer moving 0.1 bar each time until it reaches 16 bar. I then need to save each individual drawing as a .jpg. This will then be used as an analogue graphic driven by 4 - 20 ma in a Graphic User Interface. Any help with this project would be much appreciated. Regards quizman Quote
dbroada Posted November 12, 2009 Posted November 12, 2009 I'm sure somebody will be along with a link to a tutorial soon so as I don't don't know where they are I won't. For now just experiment with the LINE, CIRCLE and MTEXT commands to get a feel for it. For "real" items you should ALWAYS draw at full size so you could get a gauge and measure & draw it then put the pointer where you want. I would say its a shame you are using LT as moving the pointer and creating a print would be easy using LISP or VBA, neither of which are available to you. All I can say is that what you are proposing is not difficult but will be VERY time consuming. Quote
ReMark Posted November 12, 2009 Posted November 12, 2009 Have you had any AutoCAD training what-so-ever? Even a basic course would cover most of what is required here to do the drawing. Quote
