astral_realm Posted November 12, 2009 Posted November 12, 2009 Every time I open new file in autocad 2009 I get a pop up window saying "select shape file" TgCad.shx when I select "cancel" nothing happens and I can work as usual.Its not a big problem but I didnt find no information at all on the TgCad.shx file so how can i skip the inconvenience of clicking cancel every time. Quote
ReMark Posted November 13, 2009 Posted November 13, 2009 This sounds vaguely familiar. I think AutoCAD is looking for a shape file. We just had a similar post within the past few days. Try using the Search feature above and type in the words shape file or look at the bottom of this page where it says Similar Threads. Quote
AlinOz Posted November 15, 2009 Posted November 15, 2009 Every time I open new file in autocad 2009 I get a pop up window saying "select shape file" TgCad.shx when I select "cancel" nothing happens and I can work as usual.Its not a big problem but I didnt find no information at all on the TgCad.shx file so how can i skip the inconvenience of clicking cancel every time. Basically, TgCad.shx will either be a Shape or Text (AutoCAD's old text format prior to being able to use TTF's). The fact that it pops up when you open a new drawing tells me that it's hiding in your prototype (Template) drawing. Locate the prototype you're using through OPTIONS and then try to purge the offender out... Hope that gets you moving in the right direction... Quote
