What's wrong whit this?
(defun c:asd (/ ent obj x y y2 pos)
 (vl-load-com)
 (if (setq ent( entsel "\nSelecione: "))
     (setq obj (vlax-ename->vla-object (car ent)))
     (setq cord (cdr ent))
     (setq x (car cord))
     (setq y (cdr cord))
     (setq y2 (= y -1))
     (setq pos (vla-get-alignment obj))
     (vla-put-backward obj 1)
     (vla-put-upsidedown obj 1)
 (if ( = pos 2)
   (vla-put-alignment obj 12)
 (if ( = pos 0)
   (vla-put-alignment obj 14)
 (vla-put-insertionpoint obj list(x y2 0))
i can't change the insertionpoint of the text.
I'm very glad for any help or improviment on this code.
Thanks!
 (vl-load-com)
     (setq x (car cord))
     (setq y (cdr cord))
     (setq y2 (= y -1))
 (if ( = pos 2)
 (if ( = pos 0)
Thanks!
Take a look at TextAlignmentPoint property
in the Help file
~'J'~
I read, but i can't fix that part, it's continues returning "; error: bad function: (800194.0 469602.0 0.0)"
Replace with this line:
(vla-put-insertionpoint obj (vlax-3D-point (list x y2 0)))
  1. You had your list defined incorrectly.
  2. You have to convert the list to a variant.
alanjt, i have tryed this, and it wont work... continues returning
"error: bad argument type: numberp: (800059.0 469502.0 0.0)"
I don't know what's happening
There are a lot of another basic mistakes here:
See how it will be works (tested slightly)
 (vl-load-com)
     (setq cord (cadr ent));; was (cdr ent)
     (setq x (car cord))
     (setq y (cadr cord));; was (cdr cord)
     (setq y2 (- y 1)) ; was (= y -1); bad syntax
 (cond (( = pos 0)
   (vla-put-insertionpoint obj (vlax-3d-point (list x y2 0)));was (vla-put-insertionpoint obj list(x y2 0))
   (vla-put-textalignmentpoint obj (vlax-3d-point (list x y2 0)));;added
 (( = pos 2)
~'J'~
Understood, many thanks!!
I don't realize i need to change boot alingn and insertion point.
Many thanks fixo.
Many thanks fixo.
You're welcome,
Cheers :)
~'J'~
