Here is what I want to accomplish with using a lisp routine:
Place all Line work and Line Type on layer “0”
Check to see if all text is on layer “0”, if not then place on layer “0”
Change all text style to Arial
Delete tiff image no matter what layer it’s on
Delete layer name Tiff_image
Purge all at least 3 times to insure that there are nothing left in the file
Zoom extents
Quick save
Close
Can anyone help me with this task?
Place all Line work and Line Type on layer “0” (what does this mean?)
Check to see if all text is on layer “0”, if not then place on layer “0” (done)
Change all text style to Arial (do you have a style named arial or do you mean the font?)
Delete tiff image no matter what layer it’s on (done)
Delete layer name Tiff_image (the purge will take care of this if there are no other objects on that layer)
(done)
Zoom extents (done)
Quick save (done)
Close (done)
(defun c:tip (/ ss ss1 en1 cnt en pth)
;;; change all text not on layer 0 to layer 0
  (setq ss1(ssget "X"
       '((0 . "MTEXT,TEXT")(410 . "Model")
       (-4 . "<NOT")(8 . "0")(-4 . "NOT>"))
       );_ssget
       );_setq
  (if ss1
(setq cnt 0)
       (while (< cnt (sslength ss1))
(setq en1(vlax-ename->vla-object(ssname ss1 cnt)))
       (vla-put-layer en1 "0")
       (setq cnt (1+ cnt))
       );_while
       );_progn
       );_if
  ;;;***delete all TIFF files in model space
(setq ss (ssget "_X" '((0 . "IMAGE")(410 . "Model"))))
  (if ss
(setq cnt 0)
(while (< cnt (sslength ss))
      (setq en(vlax-ename->vla-object(ssname ss cnt)))
(setq pth(vla-get-imagefile en))
       (if(=(strcase(vl-filename-extension pth))".TIFF")
(command "-image" "detach" (vl-filename-base pth))
       );_if
(setq cnt (1+ cnt))
       );_while
       );_progn
       );_if
  ;;;*** purge 3 times***
  (command "-purge" "ALL" "" "NO")
  ;;;*** zoom extence
  (command "zoom" "extents")
  ;;;*** quick save
  (command "qsave")
  ;;;*** close
  (command "close")
 );_defun
Since I only did half the work I’m only charging $500,000,00
please credit my paypal account.
[/code]Since I only did half the work I’m only charging $500,000,00
Dang! I want a piece of that. :xmas:
I looked, but couldn't find it. How can you find the image file name in plain Autolisp? -David
It's in the dictionary......I'm pretty sure it is.
Thanks. I'll take a look see. -David
Sure it is
(setq imagename (cdr (assoc 1
       (entget (cdr (assoc 340 (entget en))))))
~'J'~
Sure it is
~'J'~
Thanks!
I'd try something like this then:
[b][color=BLACK]([/color][/b]defun c:cande [b][color=FUCHSIA]([/color][/b]/ ss i en ed im[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"*LINE,*TEXT"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_.CHANGE"[/color] ss [color=#2f4f4f]""[/color] [color=#2f4f4f]"_P"[/color] [color=#2f4f4f]"_LA"[/color] [color=#2f4f4f]"0"[/color] [color=#2f4f4f]""[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]cond [b][color=NAVY]([/color][/b][b][color=MAROON]([/color][/b]tblsearch [color=#2f4f4f]"STYLE"[/color] [color=#2f4f4f]"ARIAL"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
       [b][color=NAVY]([/color][/b][b][color=MAROON]([/color][/b]or [b][color=GREEN]([/color][/b]findfile [color=#2f4f4f]"ARIAL.SHX"[/color][b][color=GREEN])[/color][/b]
            [b][color=GREEN]([/color][/b]findfile [color=#2f4f4f]"ARIAL.PFB"[/color][b][color=GREEN])[/color][/b]
            [b][color=GREEN]([/color][/b]findfile [color=#2f4f4f]"ARIAL.TTF"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
        [b][color=MAROON]([/color][/b]command [color=#2f4f4f]"_.STYLE"[/color] [color=#2f4f4f]"ARIAL"[/color] [color=#2f4f4f]"ARIAL"[/color][b][color=MAROON])[/color][/b]
        [b][color=MAROON]([/color][/b]while [b][color=GREEN]([/color][/b]> [b][color=BLUE]([/color][/b]getvar [color=#2f4f4f]"CMDACTIVE"[/color][b][color=BLUE])[/color][/b] 0[b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]command [color=#2f4f4f]""[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
       [b][color=NAVY]([/color][/b]T
        [b][color=MAROON]([/color][/b]command [color=#2f4f4f]"_.STYLE"[/color] [color=#2f4f4f]"ARIAL"[/color] [color=#2f4f4f]"TXT"[/color][b][color=MAROON])[/color][/b]
               [b][color=GREEN]([/color][/b]command [color=#2f4f4f]""[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"*TEXT"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]setq i [b][color=MAROON]([/color][/b]sslength ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]minusp [b][color=BLUE]([/color][/b]setq i [b][color=RED]([/color][/b]1- i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b]
                   ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]entmod [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 7 [color=#2f4f4f]"ARIAL"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 7 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"IMAGE"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
                   im [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 1 [b][color=RED]([/color][/b]entget [b][color=PURPLE]([/color][/b]cdr [b][color=TEAL]([/color][/b]assoc 340 [b][color=OLIVE]([/color][/b]entget en[b][color=OLIVE])[/color][/b][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]= [color=#2f4f4f]".TIF"[/color] [b][color=BLUE]([/color][/b]substr im [b][color=RED]([/color][/b]- [b][color=PURPLE]([/color][/b]strlen im[b][color=PURPLE])[/color][/b] 4[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                 [b][color=GREEN]([/color][/b]entdel en[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]> [b][color=MAROON]([/color][/b]getvar [color=#2f4f4f]"DBMOD"[/color][b][color=MAROON])[/color][/b] 0[b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_.PURGE"[/color] [color=#2f4f4f]"_All"[/color] [color=#2f4f4f]"_No"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.ZOOM"[/color] [color=#2f4f4f]"_E"[/color]
          [color=#2f4f4f]"_.QSAVE"[/color]
          [color=#2f4f4f]"_.CLOSE"[/color][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
Untested -David
Hey thanks a lot, payment will be sent by dog team from alaska, let me know when it gets there......:D
jimmy
jimmy
Dog was stop on Canadian border due to H1N1 :D
The credit transfer was saved as a file to a hard disk. That disk has been read and the hex code is being copied (with pointers) to post-it notes and sent via carrier pigeon.
Incidentally, what would a dragon do in this day and age, what with most of the worlds money being stored and transferred electronically? Would it hoard credit cards? Would it sleep on the New York Stock Exchange?
*EDIT* I just realized that had nothing to do with anything. *backs away slowly*
