HMA peter Posted November 14, 2009 Posted November 14, 2009 I accidentally overwrote a cad file with an earlier file. Is there any way of retieving the later file even if I have closed the program and switched off my computer? please! Quote
nukecad Posted November 14, 2009 Posted November 14, 2009 If you have 'Create a Backup' selected in the TOOLS > OPTIONS > SAVE then you will have a file called by the same name as the .dwg but with an extension of .bak. This will be saved in the same directory as the drawing. This is a copy of the drawing as it was saved the time before the last save. To get it back then just change the .bak to .dwg (you should change the name as well to be on the safe side and not overwrite the latest saved version). ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ If this dosnt work then there is another option if you have set Automatic saves every xx minutes. In this case you will have somewhere a set of .sv$ files. These are saved in the directory you have set in TOOLS > OPTIONS > FILES > Automatic Save File Pathname. The name usually looks something like- my_drawing_1234567_08_04_29.sv$ if you change this to- my_drawing_1234567_08_04_29.dwg then it should open as a normal drawing file. This dosnt always work; it depends on whever you have set automatic saves to FULL or INCREMENTAL but its worth a go. Quote
HMA peter Posted November 14, 2009 Author Posted November 14, 2009 To Nuke cad Thank you very much. very much appreciated - i will try the things you suggest and try to keep my job!!! Quote
ReMark Posted November 15, 2009 Posted November 15, 2009 Do you even have AutoCAD set up to save file as .bak? Quote
Cad64 Posted November 15, 2009 Posted November 15, 2009 i will try the things you suggest and try to keep my job!!! Doesn't your company perform a nightly backup of all files on the server? Can't you go back to the tapes from yesterday and retrieve the file? Quote
BIGAL Posted November 27, 2009 Posted November 27, 2009 As an computer dealer I was asked by my former boss to call in someone who lived close by to a panicking customer , the computer was 1 month old it basicly died, I asked the architect who was also sold a tape backup unit within the unit "did you do any backups ? " his reply "No !" Very expensive lesson for a couple of minutes work every now and then, if on a network copy to somewhere else every day. How many days work can you afford to lose ? Quote
mrbucket Posted November 27, 2009 Posted November 27, 2009 Gotta do backups as others have said. Sometimes, depending on how much work I get done, I will save am and pm files, that way I only need to redo a mornings or afternoons work. If you have no earlier save dates, nukecad's way might be your only choice. As Bigal mentioned, save it off the computer your using just in case. Cheap way to do it is a flash drive, they are so cheap now, get a 4 gig one and back-up the previous dates on external hard drive when you can get one. Quote
dbroada Posted November 27, 2009 Posted November 27, 2009 you probably WON'T have any sv$ files. They get cleared everytime AutoCAD exits cleanly. They will only be there in the event of AutoCAD closing unexpectedly. Quote
