VBA Displaying Pick point coordinates in UserForm Text box
Hi CADaholics,
I am just starting vba and I have designed a UserForm with combination text and command buttons. There is a Pick button to let user pick a point in Graphics screen and return to Userform. How do I get the coordinates to display in the Northing textbox, Easting textbox etc.. e.g set the value of the textbox with the right variable and display it.
I have actually already written the program in Lisp but would like to go vba or maybe dcl would be easier?
Thanks
Scuba
Hi CADaholics,
Thanks
Scuba
Please post the code you have written in an effort to resolve the problem,
and our members would be happy to provide some guidance.
Be sure to include a description of any errors you are encountering as well.
~'J'~
Ok I got this from autocad2006 VBA book by Joe Sutphin.
It works ok I think but I want the resulting coordinates from the pick point physically displayed in the right text boxes on the User form.
Do I write something under txt1X_change()?
In other words, give the user a chance to write coordinates in or pick coordinates from ACAD graphics screen.
Private Sub cmdPick_Click()
Dim Point As Variant
On Error Resume Next
'hide the UserForm
Traverse.Hide
'ask user to select a point
Point = ThisDrawing.Utility.GetPoint(, "Select a Point")
If Err Then Exit Sub
'assign values to appropriate textbox
txt1X = Point(0): txt1Y = Point(1): txt1Z = Point(2)
'redisplay the UserForm
Traverse.Show
End Sub
If the “txt1” refer to textbox then this should work:
Traverse.txt1X.Text = Cstr(Point(0))
Traverse.txt1Y.Text = Cstr(Point(1))
Traverse.txt1Z.Text = Cstr(Point(2))
VBA would likely do the type conversion for you, but an explicit Cstr() can’t hurt.
Hey Thanks alot Seant! thats perfect! was probably pretty simple but now I can confuse my brain even more and try and write the rest!:wink:
