KiLLiNG-TiME Posted November 16, 2009 Posted November 16, 2009 Hi all Have made a Dynamic Block of a door which is 1:1 & I want to put some annotative attributes in as a TAG but I seem to be having problems with the last bit i.e. the TAG 2008 any advice please Its only the Attributes which i want to be annotative. Quote
NBC Posted November 16, 2009 Posted November 16, 2009 If your block is annotative, I have found it is not a good idea to make any attributes of the annotative block to be annotative Quote
KiLLiNG-TiME Posted November 16, 2009 Author Posted November 16, 2009 If your block is annotative, I have found it is not a good idea to make any attributes of the annotative block to be annotative Agreed with you there ...i have found i can have a nested block with annotative attributes but of course i cannot edit the attributes !!! How do i do this simply task ..its gottern me beat at the moment, The define attributes command in the block editor let you add annotative attributes ! why whats the bloody point ...!!! (it should be greyed out in my view) So can i have attributes in a Dynamic block that i can edit that will be annotative ? Quote
NBC Posted November 16, 2009 Posted November 16, 2009 When a block is annotative, the attributes also become annotative, by default - therefore there is no real reason to make them annotative manually. In answer to your last question: Yes Quote
KiLLiNG-TiME Posted November 16, 2009 Author Posted November 16, 2009 When a block is annotative, the attributes also become annotative, by default - therefore there is no real reason to make them annotative manually.In answer to your last question: Yes Thank would you mind just writing down the steps please.. As i read it i have a door block drawn at 1:1 I put the attributes in but i want them to scale, but they should not be annotative, but the block must be annotative so that they scale, so how do you stop the door from scaling then ? or am i just reading this all wrong ..thanks for you help btw NBC am just an old user getting his head around annotative attributes or not as the case my be! Quote
KiLLiNG-TiME Posted November 16, 2009 Author Posted November 16, 2009 Ok i am almost there i think the attributes have to be annotative but only at 1:1 to make the block annotative...just have to get the ******s to stay in the correct location...not easy to test location at different annotations Even if i lock postion as my attributes are not stacked but in line i.e. after each other & when i anno after insertion the attributes move !!! Quote
KiLLiNG-TiME Posted November 24, 2009 Author Posted November 24, 2009 Given up decided to have a separate block for the tag much easier. Quote
