zer0_code Posted November 16, 2009 Posted November 16, 2009 Public Function Oku() 'Dim objacad As AcadApplication Dim thisdrawing As AcadDocument Dim objBlok As AcadBlockReference Dim element As Object Dim ArrayAttributes As Variant Set objacad = CreateObject("AutoCAD.Application") objacad.Documents.Open (DwgName) Set thisdrawing = objacad.ActiveDocument 'objacad.Visible = True For Each element In thisdrawing.ModelSpace If element.EntityType = 7 Then If element.HasAttributes = True Then Set objBlok = element ArrayAttributes = element.GetAttributes If objBlok.Name = blok_adi Then adet = UBound(ArrayAttributes) - LBound(ArrayAttributes) For j = LBound(ArrayAttributes) To UBound(ArrayAttributes) Matrix(k, j, 1) = ArrayAttributes(j).TagString Matrix(k, j, 2) = ArrayAttributes(j).TextString Next Else For i = LBound(ArrayAttributes) To UBound(ArrayAttributes) If ArrayAttributes(i).TagString = tag_adi Then adet = UBound(ArrayAttributes) - LBound(ArrayAttributes) For j = LBound(ArrayAttributes) To UBound(ArrayAttributes) Matrix(k, j, 1) = ArrayAttributes(j).TagString Matrix(k, j, 2) = ArrayAttributes(j).TextString Next 'MsgBox "Attribute Değeri : " & ArrayAttributes(I).TextString GoTo sonraki End If Next End If End If End If sonraki: Next objacad.Quit End Function I was using the above code to read attributes of blocks in dwg files. Now I need to do a similar thing. I need to read text object values with a specific layer in a dwg file. The above code works fine. What it does is: 1. Opens the target dwg file 2. Checks for entitytype is a block or not 3. Checks for entity has attributes or not 4. If the element has attributes, it reads the attribute values Now I need to revise my code but I don't know how ! Any help would be appriciated. Things I wonder: 1. how can I check if an element is a text or not 2. how can I specify a layer and look for the object in that layer I guess i may figure out the rest if I sum1 would show me the way Thanks & best wishes from Turkey Quote
jalucerol Posted November 16, 2009 Posted November 16, 2009 1.- Use a SelectionSet object, filtering by text. 2.- Use other SelectionSet, filtering by specified layer. SelectionSet example: 'Seccion: crea un SelectionSet Dim selectionSet1 As AcadSelectionSet 'selectionSet1.Delete Set selectionSet1 = acadapp.ActiveDocument.SelectionSets.Add("BloquesSS") 'Fin de seccion 'Seccion: agrega objectos al selectionSet1 Dim FilterType(0) As Integer Dim FilterData(0) As Variant FilterType(0) = 1 FilterData(0) = "Text" 'fin de seccion Quote
