verbena1 Posted November 16, 2009 Posted November 16, 2009 I can not find the cut extrude command in autocad 2009/3D. Quote
ReMark Posted November 16, 2009 Posted November 16, 2009 Cut extrude command? Are you referring to the SLICE command? Try the Home tab then look at the Solid Editing panel. Click on that black arrow in the bottom right hand corner. SLICE is located at the far right hand end of the flyout. Quote
JD Mather Posted November 16, 2009 Posted November 16, 2009 I can not find the cut extrude command in autocad 2009/3D. You must be coming from a SoldiWorks background. To cut extrude use Presspull command or Extrude as a solid and then do a boolean Subtract (like Combine -Cut in SWx). Check out the tutorials in my signature. If my assumption is correct that you are coming from SWx background you might want to check out Autodesk Inventor which is more like SWx. Students can download Inventor for free from http://www.autodesk.com/edcommunity and register to activate free 13-month student license. Quote
ReMark Posted November 16, 2009 Posted November 16, 2009 Cut - Extrude and Combine - Cut. What other combination commands (not sure if that is the correct terminology) does a program like Solidworks have? Does Inventor emmulate the same nomenclature as well? Just curious. Quote
verbena1 Posted November 16, 2009 Author Posted November 16, 2009 i still can not make a cut extrude in autocad 2009. which command is the best to do it please thanks so much Quote
JD Mather Posted November 16, 2009 Posted November 16, 2009 Cut - Extrude and Combine - Cut. What other combination commands (not sure if that is the correct terminology) does a program like Solidworks have? Does Inventor emmulate the same nomenclature as well? The two programs are essentially identical. SWx has a tool for Extrude and another tool for Extrude Cut. Inventor has only one Extrude tool, but with options to Join, Cut, Intersect or create new solid body. The functionality is identical - just different icons or options to accomplish the same thing. Combine - join, cut or whatever is similar to AutoCAD with the advantage of an option to preserve original rather than having to make a copy like you do in AutoCAD. Particularly useful in things like associative core/cavity mold generation where the mold changes if the model geometry changes. Quote
ReMark Posted November 16, 2009 Posted November 16, 2009 JDM provided you with instructions. What exactly is the problem you are experiencing? Quote
