Guest msdins Posted August 8, 2005 Posted August 8, 2005 I have to insert about 500 blocks to make a master file, is it possible to insert them all at once? They all need to be inserted at "0,0" scale of "1" and a rotation of "0". Any help would be greatly appreciated. Quote
devitg Posted August 8, 2005 Posted August 8, 2005 You can do it with a SCRIPT . A script file is a text file that reperesent eacn keystroke .so for it it shall be as follow -insert drawing001 0,0 1 1 0 -insert drawing002 0,0 1 1 0 -insert drawing003 0,0 1 1 0 -insert drawing004 0,0 1 1 0 -insert drawing005 0,0 1 1 0 -insert drawing006 0,0 1 1 0 -insert drawing007 0,0 1 1 0 -insert drawing008 0,0 1 1 0 -insert drawing009 0,0 1 1 0 -insert drawing010 0,0 1 1 0 -insert drawing011 0,0 1 1 0 -insert drawing012 0,0 1 1 0 -insert drawing013 0,0 1 1 0 -insert drawing014 0,0 1 1 0 -insert drawing015 0,0 1 1 0 -insert drawing016 0,0 1 1 0 -insert drawing017 0,0 1 1 0 save it as insert-my-dwg.scr and at the command line put SCRIPT then the dialogbox will ask you to select a SCR file , chose it and that's all Note the space after each statement it is equal a enter, and the minus sign before insert , it is to avoid open the insert dailog box Quote
