i am currently using AutoCAD LT 2006 and can't seem to get BEdit command working?
any ideas?
You're not giving us much to work with. :unsure:
What seems to be the problem? What happens when you type BEDIT at the command line?
this is the message i get on the command line:
bedit Unknown command "BEDIT". Press F1 for help.
which doesn't help me
any ideas?
Oh, oops. :oops:
Bedit doesn't exist in Autocad 2006 LT. It was added to LT in 2007.
is there any way of getting it to run with an add-on?
Sorry, I don't know of any add-on that will give you the Bedit functionality, especially since Autodesk added the command to the program in 2007.
Have you thought about upgrading?
we will be upgrading in the next couple of months, i just thought there may be an add on to resolve the issue in the meantime
cheers,:bloodshot:
The quick and dirty method would be to Wblock your block to it's own drawing and then edit the drawing itself.
Bedit is (as I understand it) basically doing this already, but with a specific set of tools brought up. Attribute editor, dynamic block toolbar (depending on version) and so on. Once you make your changes, you save them and then reinsert the drawing (block).
Glen
