scubastu Posted November 22, 2009 Posted November 22, 2009 Maybe a silly question, but how do you get a rotation from a dynamic block? My block has scale and rotation dynamic properties in it. The Rotation shows in the Properties bar as Angle1. How can I retrieve this in lisp? Ultimately I want to realign the rotation of the block to another object I select e.g. line, polyline etc.. Thanks in advance Quote
Lee Mac Posted November 22, 2009 Posted November 22, 2009 example: (defun c:test ( / ent ) (vl-load-com) (if (setq ent (car (entsel "\nSelect Block: "))) (mapcar (function (lambda (property) (vlax-get property 'value))) (vlax-invoke (vlax-ename->vla-object ent) 'getDynamicBlockProperties)))) Quote
fixo Posted November 22, 2009 Posted November 22, 2009 Maybe a silly question, but how do you get a rotation from a dynamic block? My block has scale and rotation dynamic properties in it. The Rotation shows in the Properties bar as Angle1. How can I retrieve this in lisp? Ultimately I want to realign the rotation of the block to another object I select e.g. line, polyline etc.. Thanks in advance I hope this will allow you to change parameters (just one at a time - sorry, not tested) (defun C:cang(/ ang blk blkname cparam props ss) (setq blkname "TestBlock" ;<--change block name here cparam "Angulo");<--change parameter name here (setq ang (getreal "\nEnter angle in degrees: ") ang (/ (* pi ang) 180) ) (if (setq ss (ssget ":S" (list (cons 0 "INSERT") (cons 2 (strcat blkname ",`*U*"))))) (progn (setq blk (vlax-ename->vla-object (ssname ss 0))) (setq props (vlax-safearray->list (variant-value (vla-getdynamicblockproperties blk)))) (foreach param props (if (eq cparam (vla-get-propertyname param)) (vlax-put-property param "Value" (vlax-make-variant ang 5)) (vla-update blk) ) ) ) ) (princ) ) (vl-load-com) ~'J'~ Quote
scubastu Posted November 22, 2009 Author Posted November 22, 2009 Thanks guys it gives me something to work with! May God bless you with a pay rise! Quote
Lee Mac Posted November 22, 2009 Posted November 22, 2009 Thanks guys it gives me something to work with! May God bless you with a pay rise! Your welcome Quote
