Setting Mtext defaults
Hi All,
Just a basic question,
How can I change all the default setting of Mtext? I can't change many things in "Format>Text Style"(like Justify)!
Cheers
Ali
Hi All,
Cheers
Ali
You can use QSELECT or FILTER to grab all them, and edit the settings in the Properties palette. :)
Thanks for your reply,
I know but I want to have my own setting as default on Mtext. So, once I use Mtext I have a text in the way that I'm looking for(no changing required after type something), then I want to drop that in to Tool Palette and have it handy.
Cheers
Cheers
Ah, that's easy. Create your MTEXT and get all the settings the way you want it, but in the text field just put something as a placeholder, anything.... like "TEXT" or "PUT TEXT HERE", etc. Then, create a block and select the text. Once you've created it as a block, save the file, and drag/drop it into which ever Tool Palette you choose. Now, right click the newly inserted Tool Palette block and when it says "Explode" click Yes. That way you can bring it in and it's ready to be "edited". Be sure to set it to whatever layer you want, or color, etc... you should get the idea. :)
nice trick! like that.
but there should be a way to define the default!
Anything is possible with learning the Programming side of things. Other than that, just hit up the Wish List at AUGI and in 10-15 years it'll become a default. lol :lol:
Sounds like an opportunity for Lee Mac, he does speak with a lisp or, isn't he talking to us?
I know he's a busy beaver. Let's hope he checks in soon.
Hi All,
Cheers
Ali
I use this on a toolbar button to Middle Center Mtext that I got from someone on these forums.
^C^C(initdia)(COMMAND ".MTEXT" PAUSE "J" "MC")
So you can start mtext and watch the command line for the options and add them into the macro like that shown above.
  • 3 years later...
I know this is an old thread but I have not seen a really good answer.
If you want all new MTEXT objects to have certain defaults you must change the settings for the font that you want to use and then select that font.
1. SELECT THE ANNOTATE TAB
2. SELECT THE FONT THAT YOU WANT
3. CHANGE THE SETTINGS
4. THESE WILL NOW BE WHAT IS USED FOR NEW MTEXT OBJECTS.
HEIGHT CAN BE SET HERE.
CLICK JUSTIFY OR SCALE TO ADJUST A SELECTION OF MTEXT OBJECTS
All new MTEXT objects for this drawing using the current font should now have these settings.
Hopefully this makes life easier than macros etc, you could create a custom font and then just import to any drawing this way.
-John
Edited by MrCrozzB
