alehasan Posted November 24, 2009 Posted November 24, 2009 Hi guys, I was wondering if anyone can help me out on this one. I have a vba lisp routine and i dont really know anything about it, just want to run this code in my auto cad, if anyone can give me step by step instructions on how to run this code in my autocad, I dont know anything about lisp so please give me complete instruction till i get it running and using in my autocad, thankyou The code is as follows: Option Explicit Function GetActiveSpace() As AcadBlock With ThisDrawing If .ActiveSpace = acModelSpace Then Set GetActiveSpace = .ModelSpace Else Set GetActiveSpace = .PaperSpace End If End With End Function Function StoreLayerStatus() As Variant Dim oLayer As AcadLayer Dim oLayers As AcadLayers Dim i As Integer With ThisDrawing Set oLayers = .Layers End With ReDim layerArr(0 To oLayers.Count - 1, 0 To 2) As Variant For Each oLayer In oLayers layerArr(i, 0) = oLayer.Name layerArr(i, 1) = oLayer.Lock layerArr(i, 2) = oLayer.Freeze On Error Resume Next oLayer.Freeze = False If Err Then Err.Clear i = i + 1 Next oLayer On Error GoTo 0 StoreLayerStatus = layerArr End Function Private Sub RestoreLayerStatus(ByVal ar As Variant) Dim oLayer As AcadLayer Dim oLayers As AcadLayers Dim i As Integer With ThisDrawing Set oLayers = .Layers End With For i = LBound(ar, 1) To UBound(ar, 1) Set oLayer = oLayers(ar(i, 0)) On Error Resume Next '<-- to bypass active layer With oLayer .Lock = ar(i, 1) .Freeze = ar(i, 2) End With If Err Then Err.Clear Next i On Error GoTo 0 End Sub Sub BlockReplace() Dim lsArr As Variant lsArr = StoreLayerStatus Dim oSpace As AcadBlock Dim varPt As Variant Dim oEnt As AcadEntity Dim oldBlkRef As AcadBlockReference Dim newBlkRef As AcadBlockReference Dim oldblkName As String Dim newblkName As String Dim layName As String Dim xscl As Double Dim yscl As Double Dim zscl As Double Dim rot As Double Dim insPt(2) As Double Dim ftype(0) As Integer Dim fdata(0) As Variant Dim dxfCode, dxfValue Dim oSset As AcadSelectionSet ThisDrawing.Utility.GetEntity oEnt, varPt, vbCrLf & "Select new block instance to replace with:" If Not TypeOf oEnt Is AcadBlockReference Then MsgBox "Selected object isn't a block reference" Exit Sub End If Set newBlkRef = oEnt If newBlkRef.IsDynamicBlock Then newblkName = newBlkRef.EffectiveName Else newblkName = newBlkRef.Name End If With ThisDrawing.SelectionSets While .Count > 0 .Item(0).Delete Wend Set oSset = .Add("$ReplaceBlocks$") End With ftype(0) = 0 fdata(0) = "INSERT" dxfCode = ftype: dxfValue = fdata oSset.SelectOnScreen dxfCode, dxfValue Set oSpace = GetActiveSpace For Each oEnt In oSset Set oldBlkRef = oEnt With oldBlkRef layName = .Layer xscl = .XScaleFactor yscl = .YScaleFactor zscl = .ZScaleFactor rot = .Rotation varPt = .InsertionPoint insPt(0) = varPt(0): insPt(1) = varPt(1): insPt(2) = varPt(2) .Delete End With Set newBlkRef = oSpace.InsertBlock(insPt, newblkName, xscl, yscl, zscl, rot) newBlkRef.Layer = layName Next oEnt RestoreLayerStatus (lsArr) ThisDrawing.Regen acActiveViewport End Sub Quote
alehasan Posted November 24, 2009 Author Posted November 24, 2009 Sorry guys forgot to tell u that this code is for replacing a PARTICULAR instance of a block with another block. Quote
Tiger Posted November 24, 2009 Posted November 24, 2009 try this explanation VBA stands for Visual BASIC for Applications and is a Microsoft package available for many applications such as Excel. Most MS Office packages come with VBA and they are loosely based on Visual BASIC and while broadly similar are not identical. A VBA routine can look something like this, this is a routine to scale blocks drawn with metric units to imperial units. Public Sub ScaleRef() Dim myObject As AcadEntity Dim myScale As Double myScale = 1 / 25.4 ThisDrawing.Utility.GetEntity myObject, basePnt, "Select an object" If myObject.ObjectName = "AcDbBlockReference*" Then basePnt = myObject.InsertionPoint End If myObject.XScaleFactor = myScale myObject.YScaleFactor = myScale myObject.ZScaleFactor = myScale End Sub To load the routine, first start up AutoCAD. Select Tools > Macro > Visual Basic Editor This will bring up the Visual Basic Editor screen. All routines are built here but if no routines are loaded it should be quite plain. Select Insert > Module and a blank code window appears, either write a new VBA routine or paste an already written routine here. Note the first line, in this code it is Public Sub ScaleRef. This means that ScaleRef is the name that is used to activate the routine. In the Visual Basic editor window to the left is a project explorer window - if multiple routines are going to be used it is recommended to change the names of the routines from the default Module1 to something more descriptive. This is done by entering a new name in the Properties box, underneath the project explorer window. Select File > Close and return to AutoCAD. Once back in AutoCAD the routine is ready to be run, this is done in two steps, first a command (vbastmt) to active VBA and then the particular routine is activated. For this routine, type the following: vbastmt at the prompt Expression: type ScaleRef Now the prompt Select an object: appears and when a block is selected it is automatically scaled from metric to imperial. When exiting AutoCAD, a dialogue box pops up asking if changes to the VBA project "Global1" should be saved, click the Yes-button. It should be saved as ACAD.dvb and saved in the Support folder. Doing this means that the routine will be loaded each time AutoCAD starts. If it is saved under another name and/or in another location, it will need to be loaded each time using the VBA Manager. The VBA Manager is found under Tools > Macro. Click Load and browse to the location of the file Quote
rkmcswain Posted November 24, 2009 Posted November 24, 2009 Hi guys,I have a vba lisp routine VBA and Lisp are two different things. Your code is VBA, not lisp. Looks like Tiger gave you the steps to run this code... Quote
alehasan Posted November 24, 2009 Author Posted November 24, 2009 Thankyou Tiger, Can u explain me what is the word used to activate my lisp routine like the one in your example. Quote
alehasan Posted November 24, 2009 Author Posted November 24, 2009 Yeah my code is vba, can someone give examply using the code i have given?? I appreciate tiger's answer but it is still confusing for me to run my code as its different to the one tiger has used in his example, thankyou Quote
Tiger Posted November 24, 2009 Posted November 24, 2009 Yeah my code is vba, can someone give examply using the code i have given?? I appreciate tiger's answer but it is still confusing for me to run my code as its different to the one tiger has used in his example, thankyou Since I know next to nothing about VBA-routines, I can't help your there. I will move this thread to the Customization-forum, you might get a faster answer there. Quote
rkmcswain Posted November 24, 2009 Posted November 24, 2009 I appreciate tiger's answer but it is still confusing for me to run my code as its different to the one tiger has used in his example, The actual code doesn't matter. The process that Tiger outlined for you is the same, just use your code. The only difference I might mention is that instead of using the "vbastmt" command at the command line, you can run the VBARUN command and choose the macro from a dialog. Note: if you are running AutoCAD 2010, then VBA is not included. You can download it from Autodesk though. Quote
