Zox Posted November 24, 2009 Posted November 24, 2009 How do I make text on dimension line bolder (thicken) because I got someone else's blueprint and their text on dimension lines is kind of weak. I tried changing lineweight in layer of dimension but nothing. Quote
bonehead411 Posted November 24, 2009 Posted November 24, 2009 If it's all dimension text you wish to change, it may be easiest to modify the textstyle used in the dimstyle. Or create a new one. Quote
dinarele Posted November 24, 2009 Posted November 24, 2009 If it's just one dim you need to be bold and if it suits you, just pick 'Arial-Bold' under Text style in properties panel. And for the line, just change the lineweight. Or you can create another dimension style and set up all line thicknesses and text style You need. Quote
Tankman Posted November 27, 2009 Posted November 27, 2009 Select the dimension, highlight it. Modify>Object>Text>Edit Select the "", highlight it. Bold the text! Close the text editor. That'll work for one dimension at a time. Lots to change? Change the font. "STYLE" on the command line. **Note** This will change all text on the drawing. Quote
