Primal Scientist Posted November 24, 2009 Share Posted November 24, 2009 Hello All, I have just started to work in 3D and I am working on a roof truss. I have noticed that I can rotate 360 degree circle on the horizontal plane, but I cannot do anything when it come to a vertical plane. Can anyone help please? Regards, Daz. Quote Link to comment Share on other sites More sharing options...
rkent Posted November 24, 2009 Share Posted November 24, 2009 First turn the UCSICON on if it isn't already. UCSICON, all, on. Now use the UCS command, Z, 90. Study the UCS command options as you will be using these frequently. Also type UCS, New, to see further "hidden" options. Also, toggle on the Dynamic UCS at the bottom of your screen. Quote Link to comment Share on other sites More sharing options...
Primal Scientist Posted November 24, 2009 Author Share Posted November 24, 2009 Thanks, Did that but I am doing something wrong, it still only rotates on the x y axis.... Quote Link to comment Share on other sites More sharing options...
rkent Posted November 24, 2009 Share Posted November 24, 2009 Sorry, should have been rotate the X or Y. UCS, X, 90 for example. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 25, 2009 Share Posted November 25, 2009 Just ROTATE3D then select objects then X or Y or Z then 90 if you draw 4 objects ie up down left right and rotate them 90 (1 is -90) you end up with a cube it is that easy then use UCS Ob to set your drawing plane to be vertical etc Remember must type "plan" to make current save it is good idea UCS S, "UCS W Plan" to go bak to real world you can work in 3 d view if you want just dont do the "Plan". Quote Link to comment Share on other sites More sharing options...
Primal Scientist Posted November 25, 2009 Author Share Posted November 25, 2009 Thanks guys. Quote Link to comment Share on other sites More sharing options...
