bspill1 Posted August 10, 2005 Posted August 10, 2005 After installing full version from student version I still have student version on the top title bar and on printed pages. Any help? Quote
Guest Bloodwig80 Posted September 13, 2005 Posted September 13, 2005 1. are you opening the correct version from your start menu? or are you clicking on a desktop shortcut? 2. if youre clicking on the correct one, try 'add & remove programs' and uninstall both versions. then re-install Full version. Quote
hendie Posted September 13, 2005 Posted September 13, 2005 and get rid of ALL STUDENT VERSION DRAWINGS !!!!! otherwise you will infect everything Quote
Spageddie Posted September 13, 2005 Posted September 13, 2005 Student version Yes do as hendie suggest...do NOT reuse any or any part of them Quote
rkmcswain Posted September 19, 2005 Posted September 19, 2005 I'll add one more to that.... DO NOT USE ANYTHING THAT WAS DRAWN IN THE STUDENT VERSION IN ANY OTHER DRAWING. Quote
bspill1 Posted September 20, 2005 Author Posted September 20, 2005 The problem turned out to be some crap left over in the registry. and uhh.....I guess I won't use any of my old student stuff. Quote
f700es Posted September 20, 2005 Posted September 20, 2005 The problem turned out to be some crap left over in the registry. and uhh.....I guess I won't use any of my old student stuff. There is a way around it (or I was told there was). If you have this all leagly then you can get a hold of your autocad dealer and let them know about it. I was told there was a way to reuse your old drawings. Quote
tli3 Posted October 10, 2009 Posted October 10, 2009 Just came across your post whilst searching for info, can I ask how you upgraded your student version to full version? I'm trying to do the same with AutoCAD 2010 student version and a new full license, do I have to uninstall and reinstall or is there a way to change the license, activation code etc.?? Thank! Quote
Cad64 Posted October 10, 2009 Posted October 10, 2009 You have replied to a thread that is 4 years old. But to answer your question, yes, you should completely uninstall the student version and then install the new software with the new license. Quote
