MSasu Posted November 25, 2009 Posted November 25, 2009 Regarding the fact that Autodesk has discontinued VBA support for AutoCAD, I’m just wondering what will happen in the future with the "vla-?" statements currently offered by AutoLISP language? I mean those are probably using the VBA technology since their names and syntax (arguments) are matching similar. And those aren’t even documented in AutoLISP help – support is given in VBA help chapters. Are those to be preserved and linked internally with .Net technology, will have names and/or syntax changed or will be simply dropped?!? Does anyone have more information about this? Quote
Freerefill Posted November 25, 2009 Posted November 25, 2009 I can't say for sure, but AutoCAD has kept a lot of outdated commands and functions, simply so that old programs will still work (backwards compatibility ftw). I cannot imagine that they would drop the vla-, vlax-, or vlr- extentions for any reason. They may not develop them further, but to be rid of them would take away a vast amount of functionality from AutoCAD, and to change them would force a vast number of its users to make major corrections to a lot of things. Quote
gile Posted November 25, 2009 Posted November 25, 2009 Hi, Both VBA and Visual LISP use the COM/ActiveX interop, C# and VB.net can use it too. IMO, the end of VBA/VB6 doesn't mean the end of the COM interop. Quote
SteveK Posted November 26, 2009 Posted November 26, 2009 I can't say for sure, but AutoCAD has kept a lot of outdated commands and functions, simply so that old programs will still work (backwards compatibility ftw). I cannot imagine that they would drop the vla-, vlax-, or vlr- extentions for any reason. They may not develop them further, but to be rid of them would take away a vast amount of functionality from AutoCAD, and to change them would force a vast number of its users to make major corrections to a lot of things. Hi, Both VBA and Visual LISP use the COM/ActiveX interop, C# and VB.net can use it too. IMO, the end of VBA/VB6 doesn't mean the end of the COM interop. If they are not develloping alisp or vlisp what are the developing? Anything that is a good idea for us to get into? Quote
gile Posted November 26, 2009 Posted November 26, 2009 If they are not develloping alisp or vlisp what are the developing? A 2010 brings some new autoLISP functions : layerstate-addlayers Adds or updates a series of layers to a layer state layerstate-compare Compares a layerstate to the layers in the current drawing layerstate-delete Deletes a layer state layerstate-export Exports a layer state to a specified file layerstate-getlastrestored Returns the name of the last restored layer state in the current drawing layerstate-getlayers Returns the layers saved in a layer state layerstate-getnames Returns a list of the layer state names layerstate-has Checks if a layer state is present layerstate-import Imports a layer state from a specified file layerstate-importfromdb Imports a layer state from a specified drawing file layerstate-removelayers Removes a list of layers from a layer state layerstate-rename Renames a layer state layerstate-restore Restores a layer state into the current drawing layerstate-save Saves a layer state in the current drawing But "what they are developing" is mostly .NET. The managed classes library grows with each new objectARX version. Quote
SteveK Posted November 26, 2009 Posted November 26, 2009 Thanks Gile. If you don't mind my asking you three more questions: - when you say .NET, for us it means to learn either VB or C#? - do you find you can do lots more with C#? - Lastly, What's your personal preference do you prefer C# or lisp? Are those layerstate's meant to be links? I get 'page not found'. Quote
alanjt Posted November 26, 2009 Posted November 26, 2009 Thanks Gile. If you don't mind my asking you three more questions:- when you say .NET, for us it means to learn either VB or C#? - do you find you can do lots more with C#? - Lastly, What's your personal preference do you prefer C# or lisp? Are those layerstate's meant to be links? I get 'page not found'. I think he was just copying them out of Help. I actually posted a bit of information on them a while back. http://www.cadtutor.net/forum/showthread.php?t=39986 They were introduced in 09, btw. Quote
gile Posted November 26, 2009 Posted November 26, 2009 SteveK, - when you say .NET, for us it means to learn either VB or C#?- do you find you can do lots more with C#? - Lastly, What's your personal preference do you prefer C# or lisp? Yes, using .NET means to learn C#, VB.net or another .NET supported language as C++, F#, J#, IronPython... I'm too newby at C# to see if .NET can do lots more, but I already think it does more and sometimes easier (as Visual LISP vs AutoLISP) I really like LISP cause it's easier to learn, faster to write, more flexible, but almost because I know it a little now. I like C# because powerfull but almost because it's new for me, and I like to learn new things. Quote
Lee Mac Posted November 26, 2009 Posted November 26, 2009 In terms of other programming, as I have said over at theSwamp, I have looked into C++, and am doing a bit of C programming currently, and, (it could just be that I am new to the language}, but no matter how much more I learn of C++/C, I still much prefer coding in LISP/VLISP... just because things seem a lot clearer, and with a more logical structure... but as I say, it may just be that I am very much an amateur in other languages, so don't really have a "global view" on things... but I am still enjoying LISP/VLISP more than any other language I have tried to learn... Quote
SteveK Posted November 26, 2009 Posted November 26, 2009 Yes, using .NET means to learn C#, VB.net or another .NET supported language as C++, F#, J#, IronPython... I'm too newby at C# to see if .NET can do lots more, but I already think it does more and sometimes easier (as Visual LISP vs AutoLISP) I really like LISP cause it's easier to learn, faster to write, more flexible, but almost because I know it a little now. I like C# because powerfull but almost because it's new for me, and I like to learn new things. Ta Gile. I'm sure newby is a relative term. If I started learning C# I'd be a newby, not able to do this. steve Quote
BKSpurgeon Posted February 22, 2017 Posted February 22, 2017 It all depends on the task at hand: that's why learning a combination of .net and lisp is good. some things are easy in lisp and others are much better handled in .net. i know in .net you can utilize LINQ. huge benefit. can you do the same with lisp? Probably not. overall i'd strongly recommend .net as a primary focus and then a general knowledge of lisp will be advantageous and personally I haven't bothered at all with VBA. my two cents. Ta Gile.I'm sure newby is a relative term. If I started learning C# I'd be a newby, not able to do this. steve Quote
