flowerrobot Posted November 26, 2009 Posted November 26, 2009 hey guys Im having a bit of truble with those two commands. Simply im finding that if i load it into one drawing1, then load in into drawing2, drawing 1 will lose its command and return ; error: Visual LISP command document mismatch: hi The reason im using it is because when it come to re-defineing commands i thought this would be easyer Here is an example where its inbeded in a Foreach function of each function and where NewKeyList is a list of what the are to be defined as (vlax-remove-cmd (cadr nm)) (if NewKeyList (progn (setenv (car nm) (nth Int_Count NewKeyList)) (setq Int_Count (1+ Int_Count)))) (eval (read (strcat "(vlax-add-cmd \""(getenv (car nm)) "\" '" (caddr nm)")"))) thanks for any input flower Quote
wizman Posted November 27, 2009 Posted November 27, 2009 hey guys Im having a bit of truble with those two commands. Simply im finding that if i load it into one drawing1, then load in into drawing2, drawing 1 will lose its command and return The reason im using it is because when it come to re-defineing commands i thought this would be easyer Here is an example where its inbeded in a Foreach function of each function and where NewKeyList is a list of what the are to be defined as (vlax-remove-cmd (cadr nm)) (if NewKeyList (progn (setenv (car nm) (nth Int_Count NewKeyList)) (setq Int_Count (1+ Int_Count)))) (eval (read (strcat "(vlax-add-cmd \""(getenv (car nm)) "\" '" (caddr nm)")"))) thanks for any input flower Could you not use for example: (if (not c:fillet) (command "._UNDEFINE" "_FILLET")) then put same command name for your lisp routine. (defun c:fillet () . . ....etc Quote
flowerrobot Posted November 27, 2009 Author Posted November 27, 2009 Sorry when i said redefining commands i am refering to routines thus (defun c:hi () (princ "hi") (princ)) (command "._UNDEFINE" "hi")) returns Unknown command name. SystemProtection-V.1.Lsp Quote
wizman Posted November 27, 2009 Posted November 27, 2009 seems like a namespace issue if you're going that way. You might like to try (Setq c:hi nil) or do a vl-load-all call Quote
flowerrobot Posted November 27, 2009 Author Posted November 27, 2009 (Setq c:hi nil) when i press hi returns ; error: no function definition: C:HI Could you explan this vl-load-all call since every thing is in a .vlx Aswell i would like it to transfer threw open doc's if possible Cheers Flower Quote
Steve Doman Posted December 5, 2009 Posted December 5, 2009 Have you tried using vl-acad-undefun? This works for me: (foreach x '(c:routine1 c:routine2 c:routineN) (vl-acad-undefun x) ) Quote
Lee Mac Posted December 5, 2009 Posted December 5, 2009 Welcome to CADTutor Steve - nice to see you here Quote
Steve Doman Posted December 5, 2009 Posted December 5, 2009 Thanks Lee! : ) Welcome to CADTutor Steve - nice to see you here Quote
flowerrobot Posted December 7, 2009 Author Posted December 7, 2009 Cheers mate works great didnt think to lookin in VL for undefun Quote
