Hello everybody,
I'm working with 3d polylines and I need a lisp to do this: to draw lines from some points perpendiculat to a 3d polyline. There are a lot of points, 3d points - I mean points in space, with Z different from 0. From each point to draw a perpendicular on 3d polyline, but on that part of poly that is closer to my point. Is it possible? Thanks!
This is an example, but unfortunately I don't have a drawing with 3d polyline, only with 2d polyline.The original 3d ply has been flatten :( Is a pipe, and anyhow, differences on Z axis are small...
polyline.dwg
Try this:
(defun c:perp (/ i ss ent pt p1 p2)
 (vl-load-com)
 (princ "\n>> Select Points >>")
 (if (setq i -1 ss (ssget '((0 . "POINT"))))
   (if (and (setq ent (car (entsel "\nSelect Curve: ")))
            (wcmatch (cdr (assoc 0 (entget ent))) "*LINE,CIRCLE,ELLIPSE,ARC"))
       (while (setq pt (ssname ss (setq i (1+ i))))
         (setq p2 (vlax-curve-getClosestPointto ent (setq p1 (cdr (assoc 10 (entget pt))))))
         (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2))))))
 (princ))
Try this:
 (vl-load-com)
 (princ))
Hey, I use something quite similar to that. :)
;;; Draw line perpendicular from selected curve
;;; Required Subroutines: AT:Entsel
;;; Alan J. Thompson, 09.29.09
(defun c:LPer (/ *error* #Ent #Obj #Point)
 (setq *error* (lambda (x) (and #Obj (vl-catch-all-apply 'vla-highlight (list #Obj :vlax-false)))))
 (and
   (setq #Ent (AT:Entsel nil "\nSelect curve: " '((0 . "*POLYLINE,ARC,LINE,CIRCLE,ELLIPSE")) nil))
   (setq #Obj (vlax-ename->vla-object (car #Ent)))
   (not (vla-highlight #Obj :vlax-true))
   (while (setq #Point (getpoint "\nSpecify point for line: "))
     (entmake (list '(0 . "LINE")
                    (cons 10 (vlax-curve-getclosestpointto (car #Ent) (trans #Point 1 0) T))
                    (cons 11 (trans #Point 1 0))
              ) ;_ list
     ) ;_ entmake
   ) ;_ while
 ) ;_ and
 (*error* nil)
) ;_ defun
The only problem is, with 3DPolylines, the vertex elevation will screw up deriving the closest point. It will often snap to the end point or something. It's really quite annoying. That's why, when trying to get a point on a 3DPolyline, you have to use (osnap (cadr ent) "_near") instead of (vlax-curve-getclosestpointto (car ent) (cadr ent)). :(
A quick test seemed to work OK, but I'm not disagreeing with you as I have limited experience indeed in the world of 3D... :wink:
It draws them to the line, they just aren't perpendicular in a top view (which, in my experience, is what you want). However, the requesting party may be asking for just what you did. It's tricky when dealing with the 3D world. I'm civil and things are 3D, but not in the fashion that some people work in 3D. I still live in a TOP view world.
Point taken, how about this then?
 (vl-load-com)
         (setq p2 (vlax-curve-getClosestPointtoprojection ent
                    (setq p1 (cdr (assoc 10 (entget pt)))) '(0 0 1)))
 (princ))
 (vl-load-com)
 (princ))
Nicely done Lee! :)
I've updated mine as well.
 (and
                    (cons 10 (vlax-curve-getclosestpointtoprojection (car #Ent) (trans #Point 1 0) '(0 0 1)))
              ) ;_ list
     ) ;_ entmake
   ) ;_ while
 ) ;_ and
 (*error* nil)
) ;_ defun
Thanks Alan :)
Well deserved, I never even looked into closestpointtoprojection.
Hello everybody,
after drawing perpendicular lines from points to a 3dpoly, I have to measure the distance between consecutive intersection 3dpoly - perpendicular line. A lisp to do this will help me a lot... See the attachment - drawing. Thanks!
3dpoly-dist.dwg
Try this: (Lee's Routine Modified)
 (vl-load-com)
 (command "_undo" "_begin")
 (if (setq i  -1
           ss (ssget '((0 . "POINT"))) )
       (setq
       (if (entmake (list '(0 . "LINE") '(8 . "perp") (cons 10 p1) (cons 11 p2)))
         (entmake
           (list '(0 . "MTEXT")
                 '(100 . "AcDbEntity")
                 '(100 . "AcDbMText")
                 '(8 . "point")
                 (cons 10 p1)
                 '(40 . 0.6)
                 '(41 . 6.03584)
                 '(71 . 1)
                 '(72 . 5)
                 (cons 1 (vl-princ-to-string (distance p1 p2)))
                 '(7 . "Standard")
                             ;'(210 0.0 0.0 1.0)
                 '(42 . 1.6)
                 '(43 . 0.6)
                 '(50 . 0.0)
                 '(73 . 1)
                 '(44 . 1.0)
 (command "_undo" "_end")
Good code Cab, but i think he is after the distances along the the 3dpoly.
Oops, Thanks Wizman.:shock:
(defun c:perp (/ i ss ent pt p1 p2 ptList LASTPT)
 (vl-load-com)
 (if (setq i  -1
       (setq ptList (cons p2 ptList))
 (if ptList
     (setq Startpt (vlax-curve-getstartpoint ent)
           Lastpt Startpt)
     ;;  sort by distance
     (setq ptList (vl-sort ptList '(lambda (e1 e2)
                                     (< (vlax-curve-getdistatpoint ent e1)
                                        (vlax-curve-getdistatpoint ent e2)))))
   (foreach pt ptList
     (if (> (distance pt Startpt) 0.001)
         (entmake
                 '(8 . "point")
                 (cons 10 (polar pt (angle pt Lastpt)(/ (distance pt Lastpt) 2.)))
                 '(40 . 0.6)
                 '(41 . 0.0)
                 '(71 .
                 '(72 . 5)
                 (cons 1 (rtos (distance pt Lastpt) 2 2))
                 '(7 . "Standard")
                             ;'(210 0.0 0.0 1.0)
                 '(50 . 0.0)
                 '(73 . 1)
                 '(44 . 1.0)
      (setq LastPt pt)
No doubt Mr Flopo will return with yet another request... :geek: o:)
No more requests.... on this subject :)
Thanks, guys!
