Grenco Posted November 27, 2009 Posted November 27, 2009 Hi there, Because i'm using a wipeout in some blocks i want to place these on top. Sometimes the blocks are placed accidentaly under lines so the line is fully visible. Because I also have a database connection which selects each block I also want to place it on top in that same routine. Public Elem As Object For Each Elem In ThisDrawing.ModelSpace With Elem If StrComp(.EntityName, "AcDbBlockReference", 1) = 0 Then If ((Elem.HasAttributes) And (Left(Elem.EffectiveName, 3) = "G_B") Or (Left(Elem.EffectiveName, 3) = "G_E") Or _ (Left(Elem.EffectiveName, 3) = "G_I") Or (Left(Elem.EffectiveName, 3) = "G_L")) Then [color=red] Elem.MoveToTop (DOESNT WORK?!)[/color] End If End If End With Next Elem The VBA help didn't help me out much... Can you guys help me? Thnx!! Quote
fixo Posted November 27, 2009 Posted November 27, 2009 Hi there, Because i'm using a wipeout in some blocks i want to place these on top. Sometimes the blocks are placed accidentaly under lines so the line is fully visible. Because I also have a database connection which selects each block I also want to place it on top in that same routine. Public Elem As Object For Each Elem In ThisDrawing.ModelSpace With Elem If StrComp(.EntityName, "AcDbBlockReference", 1) = 0 Then If ((Elem.HasAttributes) And (Left(Elem.EffectiveName, 3) = "G_B") Or (Left(Elem.EffectiveName, 3) = "G_E") Or _ (Left(Elem.EffectiveName, 3) = "G_I") Or (Left(Elem.EffectiveName, 3) = "G_L")) Then [color=red] Elem.MoveToTop (DOESNT WORK?!)[/color] End If End If End With Next Elem The VBA help didn't help me out much... Can you guys help me? Thnx!! here is an example from Help, slightly changed hope this make a sense Option Explicit Sub OrderToTop() ' This example creates a SortentsTable object and ' changes the draw order of selected object(s) to top. Dim oSset As AcadSelectionSet Dim oEnt Dim i As Integer Dim setName As String setName = "$Order$" 'Make sure selection set does not exist For i = 0 To ThisDrawing.SelectionSets.Count - 1 If ThisDrawing.SelectionSets.Item(i).Name = setName Then ThisDrawing.SelectionSets.Item(i).Delete Exit For End If Next i Set oSset = ThisDrawing.SelectionSets.Add(setName) oSset.SelectOnScreen If oSset.Count > 0 Then ReDim arrObj(0 To oSset.Count - 1) As AcadObject 'Process each object i = 0 For Each oEnt In oSset Set arrObj(i) = oEnt i = i + 1 Next End If On Error GoTo Err_Control 'Get an extension dictionary and, if necessary, add a SortentsTable object Dim eDictionary As Object Set eDictionary = ThisDrawing.ModelSpace.GetExtensionDictionary ' Prevent failed GetObject calls from throwing an exception On Error Resume Next Dim sentityObj As Object Set sentityObj = eDictionary.GetObject("ACAD_SORTENTS") On Error GoTo 0 If sentityObj Is Nothing Then ' No SortentsTable object, so add one Set sentityObj = eDictionary.AddObject("ACAD_SORTENTS", "AcDbSortentsTable") End If 'Move selected object(s) to the top sentityObj.MoveToTop arrObj Application.Update Exit Sub Err_Control: If Err.Number 0 Then MsgBox Err.Description End Sub ~'J'~ Quote
Grenco Posted November 27, 2009 Author Posted November 27, 2009 Thanks for your response fixo! It works fine. One simple question is left.... How to fill that oSset? I don't want to select on screen. I made a own range of objects: Sub OrderToTop() ' This example creates a SortentsTable object and ' changes the draw order of selected object(s) to top. Dim oSset As AcadSelectionSet Dim oEnt Dim I As Integer Dim setName As String setName = "$Order$" 'Make sure selection set does not exist For I = 0 To ThisDrawing.SelectionSets.Count - 1 If ThisDrawing.SelectionSets.Item(I).Name = setName Then ThisDrawing.SelectionSets.Item(I).Delete Exit For End If Next I Set oSset = ThisDrawing.SelectionSets.Add(setName) [color=red] ReDim ssobjs(0 To ThisDrawing.Blocks.Count - 1) As AcadBlock[/color] [color=red] I = 0[/color] [color=red] For I = 0 To ThisDrawing.Blocks.Count - 1[/color] [color=red] Set ssobjs(I) = ThisDrawing.Blocks.Item(I)[/color] [color=red] Next[/color] [color=red] ' Add the array of objects to the selection set[/color] [color=red] [b]oSset.AddItems ssobjs[/b][/color] If oSset.Count > 0 Then ReDim arrObj(0 To oSset.Count - 1) As AcadObject 'Process each object I = 0 For Each oEnt In oSset Set arrObj(I) = oEnt I = I + 1 Next End If On Error GoTo Err_Control 'Get an extension dictionary and, if necessary, add a SortentsTable object Dim eDictionary As Object Set eDictionary = ThisDrawing.ModelSpace.GetExtensionDictionary ' Prevent failed GetObject calls from throwing an exception On Error Resume Next Dim sentityObj As Object Set sentityObj = eDictionary.GetObject("ACAD_SORTENTS") On Error GoTo 0 If sentityObj Is Nothing Then ' No SortentsTable object, so add one Set sentityObj = eDictionary.AddObject("ACAD_SORTENTS", "AcDbSortentsTable") End If 'Move selected object(s) to the top sentityObj.MoveToTop arrObj Application.Update Exit Sub Err_Control: If Err.Number <> 0 Then MsgBox Err.Description Where the text is bold it gives error: Method 'AddItems' of object 'IAcadSelectionSet' failed. I've tried to dim ssobjs as Object, AcadEnitity, Variant and AcadObject and it stil doesnt work. How come? What's wrong? What's the answer? Quote
fixo Posted November 27, 2009 Posted November 27, 2009 Thanks for your response fixo! It works fine. One simple question is left.... How to fill that oSset? I don't want to select on screen. I made a own range of objects: Sub OrderToTop() ' This example creates a SortentsTable object and ' changes the draw order of selected object(s) to top. Dim oSset As AcadSelectionSet Dim oEnt Dim I As Integer Dim setName As String setName = "$Order$" 'Make sure selection set does not exist For I = 0 To ThisDrawing.SelectionSets.Count - 1 If ThisDrawing.SelectionSets.Item(I).Name = setName Then ThisDrawing.SelectionSets.Item(I).Delete Exit For End If Next I Set oSset = ThisDrawing.SelectionSets.Add(setName) [color=red] ReDim ssobjs(0 To ThisDrawing.Blocks.Count - 1) As AcadBlock[/color] [color=red] I = 0[/color] [color=red] For I = 0 To ThisDrawing.Blocks.Count - 1[/color] [color=red] Set ssobjs(I) = ThisDrawing.Blocks.Item(I)[/color] [color=red] Next[/color] [color=red] ' Add the array of objects to the selection set[/color] [color=red] [b]oSset.AddItems ssobjs[/b][/color] If oSset.Count > 0 Then ReDim arrObj(0 To oSset.Count - 1) As AcadObject 'Process each object I = 0 For Each oEnt In oSset Set arrObj(I) = oEnt I = I + 1 Next End If On Error GoTo Err_Control 'Get an extension dictionary and, if necessary, add a SortentsTable object Dim eDictionary As Object Set eDictionary = ThisDrawing.ModelSpace.GetExtensionDictionary ' Prevent failed GetObject calls from throwing an exception On Error Resume Next Dim sentityObj As Object Set sentityObj = eDictionary.GetObject("ACAD_SORTENTS") On Error GoTo 0 If sentityObj Is Nothing Then ' No SortentsTable object, so add one Set sentityObj = eDictionary.AddObject("ACAD_SORTENTS", "AcDbSortentsTable") End If 'Move selected object(s) to the top sentityObj.MoveToTop arrObj Application.Update Exit Sub Err_Control: If Err.Number <> 0 Then MsgBox Err.Description Where the text is bold it gives error: Method 'AddItems' of object 'IAcadSelectionSet' failed. I've tried to dim ssobjs as Object, AcadEnitity, Variant and AcadObject and it stil doesnt work. How come? What's wrong? What's the answer? Sorry, but you confuse concepts of AcadBlock and AcadBlockReference Please, take a look at the Help file about Here is the code without of using selection set Sub OrderToTop() ' This example creates a SortentsTable object and ' changes the draw order of inserted block regerence(s) to top. Dim oEnt As AcadEntity Dim oLayout As AcadLayout Dim I As Integer Dim ssobjs() As AcadEntity I = 0 For Each oLayout In ThisDrawing.Layouts For Each oEnt In oLayout.Block If TypeOf oEnt Is AcadBlockReference Then ReDim Preserve ssobjs(I) As AcadEntity Set ssobjs(I) = oEnt I = I + 1 End If Next Next On Error GoTo Err_Control 'Get an extension dictionary and, if necessary, add a SortentsTable object Dim eDictionary As Object Set eDictionary = ThisDrawing.ModelSpace.GetExtensionDictionary ' Prevent failed GetObject calls from throwing an exception On Error Resume Next Dim sentityObj As Object Set sentityObj = eDictionary.GetObject("ACAD_SORTENTS") On Error GoTo 0 If sentityObj Is Nothing Then ' No SortentsTable object, so add one Set sentityObj = eDictionary.AddObject("ACAD_SORTENTS", "AcDbSortentsTable") End If 'Move selected object(s) to the top sentityObj.MoveToTop ssobjs 'arrObj Application.Update Exit Sub Err_Control: If Err.Number <> 0 Then MsgBox Err.Description End Sub ~'J'~ Quote
Grenco Posted November 27, 2009 Author Posted November 27, 2009 Always a tricky part. AcadBlocks etc.... But to the point: IT WORKS GREAT! Thank you very plenty!!! :wink: Quote
fixo Posted November 27, 2009 Posted November 27, 2009 Always a tricky part. AcadBlocks etc.... But to the point: IT WORKS GREAT! Thank you very plenty!!! :wink: Glad to help Cheers ~'J'~ Quote
