fer250 Posted November 28, 2009 Posted November 28, 2009 I am currently working on a project and I am facing the following problem on how to change the ucs of a block. Is there some way which this can be done? Thanks fer250 Quote
fer250 Posted November 28, 2009 Author Posted November 28, 2009 i have a problem in changing the ucs of a block when it is already blocked because when im trying i always stays the same as when i blocked it the first time Quote
fer250 Posted November 28, 2009 Author Posted November 28, 2009 hi i am having aproblem in changing the ucs of a block whilst it is already blocked Quote
SEANT Posted November 28, 2009 Posted November 28, 2009 If a block already exists in a drawing then the BEDIT command will allow the reorientation of the Block’s geometry. For instance, the insertion point can be reset by moving the geometry to the appropriate location with regard to the Block Editor’s origin (0,0,0). In a similar fashion, if the block is part of a library (i.e., resides in it’s own drawing file ready for insertion into other files) the general orientation can be modified by opening the Block’s .DWG file and moving, or rotating, the geometry with reference to the files World Coordinate System’s origin (0,0,0). Quote
