Bizkit Posted August 8, 2008 Share Posted August 8, 2008 Is it possible to link text from Excel cells to attributes in a block ... We basically have to make over 100 drawings that have 100 diffrent borders with diffrent data in them...And we would like to have them all in one central location. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 8, 2008 Share Posted August 8, 2008 Yes it is. Take a look at this: http://thecadgeek.com/blog/2008/03/12/update-block-attributes-using-excel/ Quote Link to comment Share on other sites More sharing options...
Bizkit Posted August 8, 2008 Author Share Posted August 8, 2008 not quite what i was looking for....I need something more dynamic to manage all this text....Even if its third party software. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 8, 2008 Share Posted August 8, 2008 Would fields and a linked database be of any usefulness? Quote Link to comment Share on other sites More sharing options...
Bizkit Posted August 8, 2008 Author Share Posted August 8, 2008 That would be a possability.....Please explain Quote Link to comment Share on other sites More sharing options...
dbroada Posted August 8, 2008 Share Posted August 8, 2008 I'm not if sure you can link to attributes directly but you might be able to set up a data link from your drawing to excel and then use fields to link to the table. This is just thinking out loud so may not work. I have had problems using fields referencing objects as it seems to only work on "this" drawing. If you cut & paste into another drawing the links get broken (I think) Quote Link to comment Share on other sites More sharing options...
Bizkit Posted August 8, 2008 Author Share Posted August 8, 2008 Please explain? Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 8, 2008 Share Posted August 8, 2008 Bizkit: If I could beg your indulgence for one brief moment and ask a favor. Could you provide a bit more detail about what you would like to do and/or the results you're looking to achieve? That would get everyone thinking along the same lines. Thanks. Quote Link to comment Share on other sites More sharing options...
Bizkit Posted August 8, 2008 Author Share Posted August 8, 2008 What I am trying to achive is a simple way to update data on a large amount of drawings for example.: I will have 100 or so Landplats one for each land owner involved in this project. I would like to have a spread sheet that has all the land owner names and have those cell with the landowner names linked to come out in the title block of each drawing. And if we get more upto date information (which we do...all the time) All that would need to happen is someone would edit the spread sheet and then re-plot the drawing. is this possible? Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 8, 2008 Share Posted August 8, 2008 I see your using Civil 3D 2008. And the link I provided above just didn't do for you. I believe that the Excel->AutoCAD and AutoCAD ->Excel linkage has finally been fully established in 2009. I just can't recall if it that was the case for 2008 products. Unfortunately, my one good source for that info is sitting in another office at the moment. None-the-less, I truely believe you can achieve your end result using blocks/attributes and Excel. Take heart, someone will come along and point us both in the right direction. Quote Link to comment Share on other sites More sharing options...
Bizkit Posted August 8, 2008 Author Share Posted August 8, 2008 We are about to Roll out Civil3D 2009....Do you mind explaing how this is better in 2009 Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 8, 2008 Share Posted August 8, 2008 I'm working on a little research. But I did stumble across this interesting tidbit from DotSoft regarding XL2CAD. Check it out. Pricing shown at bottom of web page. http://www.dotsoft.com/xl2cad.htm Quote Link to comment Share on other sites More sharing options...
CmdrDuh Posted August 8, 2008 Share Posted August 8, 2008 Option Explicit Public Sub PushAttributes() Dim objSelSet As AcadSelectionSet Dim objExcel As Excel.Application Dim objExcelSheet As Excel.Worksheet Dim intActR As Integer Dim blnFoundAttributes As Boolean Dim blnRunning As Boolean Dim strDwgNo As String Dim strProjectName As String Dim strLogName As String Dim foundCell As Range Dim intType(0 To 1) As Integer Dim varData(0 To 1) As Variant Dim objBlkRef As AcadBlockReference Dim atts As Variant Dim objSelCol As AcadSelectionSets Dim XL(6) As String Dim objAttRef As AcadAttributeReference On Error GoTo Err_Control: ThisDrawing.SetVariable "PROJECTNAME", "PushAtts" Set objSelCol = ThisDrawing.SelectionSets If objSelCol.Count > 0 Then For Each objSelSet In objSelCol If objSelSet.Name = "Title" Then objSelSet.Delete Exit For End If Next End If strProjectName = ThisDrawing.GetVariable("Projectname") strLogName = "c:\PMS\" & strProjectName & ".xls" blnRunning = IsAppRunning If blnRunning Then Set objExcel = GetObject(, "Excel.Application") If objExcel.ActiveWorkbook = strProjectName Then objExcel.Workbooks.Open strLogName Set objExcelSheet = objExcel.ActiveWorkbook.Sheets("Sheet1") End If Else Set objExcel = CreateObject("Excel.Application") objExcel.UserControl = True objExcel.Visible = True objExcel.Workbooks.Open strLogName objExcel.Sheets("Sheet1").Activate Set objExcelSheet = objExcel.ActiveWorkbook.Sheets("Sheet1") End If ' objExcel.Workbooks.Open strLogName ' Set objExcelSheet = objExcel.ActiveWorkbook.Sheets("Sheet1") strDwgNo = Left(ThisDrawing.Name, Len(ThisDrawing.Name) - 4) Set foundCell = objExcelSheet.Range("b4", objExcelSheet.Range("b4").End(xlDown)).Find(strDwgNo) If foundCell Is Nothing Then MsgBox ("Did not find a drawing #") objExcel.ActiveWorkbook.Save objExcel.Quit Exit Sub Else foundCell.Activate intActR = objExcel.ActiveCell.Row Set foundCell = Nothing End If XL(0) = StrConv(objExcelSheet.Cells(intActR, 1).Value, 1) 'Sheet Number XL(1) = StrConv(objExcelSheet.Cells(intActR, 2).Value, 1) 'Drawing Number XL(2) = StrConv(objExcelSheet.Cells(intActR, 3).Value, 1) 'Revision Number XL(3) = StrConv(objExcelSheet.Cells(intActR, 4).Value, 1) 'Code Number XL(4) = StrConv(objExcelSheet.Cells(intActR, 5).Value, 1) 'Line 1 XL(5) = StrConv(objExcelSheet.Cells(intActR, 6).Value, 1) 'Line 2 XL(6) = StrConv(objExcelSheet.Cells(intActR, 7).Value, 1) 'Line 3 Set objSelSet = objSelCol.Add("Title") intType(0) = 0: varData(0) = "INSERT" intType(1) = 2: varData(1) = "TITLINFO,VTITLINFO,8.5x11_BDR,vinfo" objSelSet.Select Mode:=acSelectionSetAll, filtertype:=intType, filterdata:=varData For Each objBlkRef In objSelSet If objBlkRef.HasAttributes Then blnFoundAttributes = True atts = objBlkRef.GetAttributes Set objAttRef = atts(0) objAttRef.TextString = XL(4) Set objAttRef = atts(1) objAttRef.TextString = XL(5) Set objAttRef = atts(2) objAttRef.TextString = XL(6) Set objAttRef = atts(3) objAttRef.TextString = XL(1) Set objAttRef = atts(4) objAttRef.TextString = XL(2) Set objAttRef = atts(5) objAttRef.TextString = XL(3) Set objAttRef = atts(6) objAttRef.TextString = XL(0) End If Next objBlkRef If Not blnRunning Then 'We started the instance, so we can close it objExcel.ActiveWorkbook.Save objExcel.Quit End If ThisDrawing.Save Exit_Here: strDwgNo = "" ThisDrawing.SetVariable "PROJECTNAME", "." Set objExcel = Nothing Set objExcelSheet = Nothing Exit Sub Err_Control: objExcel.Quit Set objExcel = Nothing Set objExcelSheet = Nothing MsgBox Err.Description, vbOKOnly, Err.Number Resume Exit_Here End Sub 'This determines how to set the Excel instance. Private Function IsAppRunning() As Boolean Dim objExcel As Excel.Application On Error Resume Next Set objExcel = GetObject(, "Excel.Application") IsAppRunning = (Err.Number = 0) Set objExcel = Nothing Err.Clear End Function Quote Link to comment Share on other sites More sharing options...
CmdrDuh Posted August 8, 2008 Share Posted August 8, 2008 The above code is what I use to take values from an excel spreadsheet and populate my titleblocks for 100's of drawings at a time. I use a script to open the dwg and call the PushAttributes. It finds the drawing number in the SS and looks at the other colums on that row, and takes that data back to autocad Quote Link to comment Share on other sites More sharing options...
CmdrDuh Posted August 8, 2008 Share Posted August 8, 2008 Bear in mind I have other stuff going on in that you might have to just erase. browse thru this, and let me know if you need help Quote Link to comment Share on other sites More sharing options...
fontebk1 Posted September 5, 2008 Share Posted September 5, 2008 I'm using your code and i'm trying to populate mutiple blocks with different lines from excel. How do you loop through each block and assign each cell to the correct block attribute? It runs throught the first block and then gives me a error "subscript out of range" Quote Link to comment Share on other sites More sharing options...
CmdrDuh Posted September 5, 2008 Share Posted September 5, 2008 Can you post what you have so far and include a dwg file with the blocks Quote Link to comment Share on other sites More sharing options...
fontebk1 Posted September 5, 2008 Share Posted September 5, 2008 I got it, its not pertty but it works. It been along time since I have done any vba. Thanks Quote Link to comment Share on other sites More sharing options...
