ILoveMadoka Posted November 30, 2009 Posted November 30, 2009 Autocad 2009 2 different drawings. 1 printer. 1 .ctb file (monchrome) Same layer colors. Plot both drawings to the same printer with the same plot settings and one comes out extremely light and the other one looks fine. The "light" drawing geometry was created in Solidworks and placed into our title block and the entities were moved to the correct layers. The drawing is too new to have had anyone "mess with it.." Listed a similar piece of text in each drawing. Color: Bylayer Linetype: Bylayer Lineweight: Bylayer Thickness: 0.0 Any ideas? TIA!! Quote
eldon Posted November 30, 2009 Posted November 30, 2009 Have you tried checking the lineweight values? Quote
ILoveMadoka Posted November 30, 2009 Author Posted November 30, 2009 The lineweight in both drawings is set to Bylayer which is .25mm in BOTH drawings. Quote
eldon Posted November 30, 2009 Posted November 30, 2009 I meant for you to check in Layer Properties Manager what the lineweight of each layer was. I receive drawings that were created in Revit, and all layers have a lineweight of 0.09. I thought that might be what is happening with your drawing, and would certainly explain the fainter print. Quote
ILoveMadoka Posted November 30, 2009 Author Posted November 30, 2009 Sorry. Misunderstood. They are all set to Default and Default is set to .25mm I tried seting them all to .35mm and there is no change to my plot. Still plotting too light. In the Pen Style Editor, Grayscale is Off and Screening is at 100%. Is there some other setvar that controls output/line weights? Quote
nukecad Posted November 30, 2009 Posted November 30, 2009 .......created in Solidworksand placed into our title block..... Is it pasted in as an OLE or a block? Another thought- perhaps "Plot with lineweights" in the plot dialogue? Quote
ILoveMadoka Posted December 1, 2009 Author Posted December 1, 2009 >>Is it pasted in as an OLE or a block? No. >> "Plot with lineweights" in the plot dialogue? With Plot Styles, Line Weights or both un-checked no change. Quote
