Hi, I am trying to resize and scale up portions of a 3-view drawing and I figured out how to import the image into autocad by using imageattach and now I am wondering if there is an easy way to outline them and save them so I can use them in a different program?
It seems to me that you are looking for a raster to vector drawing converter.
I have used wintopro and created a .dxf file. So far they take a lot of work depending on how Wintopro is set up. (Not very good)
The best way I have found to do this. is to attach a raster image to the drawing on layer "0"
I can then use the scale command to resize the referance image using an item in the image that is a known distance.
I always insert the drawings @ 0,0 and use referance for scaling.
Not a "clean" task.
You could print the *.jpg or *.bmp to a *.pdf file.
Convert the *.pdf to a *.dxf and go to work scale and clean up the drawing.
You will find the entire drawing is more than likely a lot of pieces (ugly).
If you have a *.pdf that was created in AutoCAD the result will be much cleaner.
Try the free download www.pdf2cad.com if they still have a trial version. Just checked, a free 30 day trial version is available.
