Dear all,
I would like use the lisp check is there any exploded dimension on dimension layer. and then I want to change all exploded dimension to other color, anyone can me me to do that ?
Thanks.
You could search for anything that isn't a "dimension" on that layer and change the colour. But is there anything else on the layer besides dimensions and exploded dimensions?
Ok just to go with yesterdays post, how does this go for you?
; Change colour of everything not a dimension on dimension layer
(defun c:CCND (/ EN I SS COUNT)
 (setq count 0)
 (and (setq ss (ssget "_X" '((-4 . "<NOT")
                 (0 . "DIMENSION,MLEADER")
                 (-4 . "NOT>")
                 (8 . "DIMENSION")
      (setq i -1)
      (while (setq en (ssname ss (setq i (1+ i))))
    (setq count (1+ count))
    (if (assoc 62 (entget en))
      (entmod (subst (cons 62 1) (assoc 62 (entget en)) (entget en)))
      (entmod (append (entget en) (list (cons 62 1))))
 (princ (strcat "\n" (itoa count) " entities changed to red.\n"))
