hello
can you help me with this question please,,:unsure:
by using autocad sketch all the views including the missing view "top" and the isometric view
the left is the front view
the right is the side view
Do you have a question or are you looking for someone to do the work for you? I don't think anyone will do the work for you. Were you taught any techniques for projecting views in orthographic projection?
no @@ i tried many times,,
i tried to draw it "isometric"
but i'm sure there is something wrong
here is my sketch
According to the first 2 sketches, there needs to be a "roof" over the open space that travels to the face that angles down.
I don't know how different Mechanical is from vanilla AutoCAD but:
Draw a 2D image to match the picture on the left, then use presspull to extrude each area to the thicknesses that you need them to be at. You may have to union the two solids to create one part if it didn't already create them as one solid.
