PUNZY Posted December 3, 2009 Posted December 3, 2009 Hi there, I did a drawing in autocad 2007 format and was opening in autocad 2008, but its takes very long time to open it. but opening in 2007 cad is fine. Dnt no why this happen. Please help. Quote
ReMark Posted December 3, 2009 Posted December 3, 2009 There's no logical explanation. 2D or 3D? Xrefs? Scalelists? File size? Is your copy of 2008 current with all updates/service packs? Quote
Cad64 Posted December 3, 2009 Posted December 3, 2009 Are you opening the drawing on the same computer you used when you created it? Or are you on a different computer? Quote
PUNZY Posted December 3, 2009 Author Posted December 3, 2009 Are you opening the drawing on the same computer you used when you created it? Or are you on a different computer? i use the same computer to open the same file, but i use 2008 to another file it opens good and fast. Quote
PUNZY Posted December 3, 2009 Author Posted December 3, 2009 yes, i have...not only my computer but i gave the same job file to a contractor to use, and they are using 2010 and having same problem. Quote
ReMark Posted December 3, 2009 Posted December 3, 2009 So you suspect it is a problem with the drawing file itself right? Quote
PUNZY Posted December 4, 2009 Author Posted December 4, 2009 So you suspect it is a problem with the drawing file itself right? this is what i can fig. out...bt dnt nw...what causing it..bt i created dynamic blocks which helpme in drawing fast....may be this...dnt nw... Quote
ReMark Posted December 4, 2009 Posted December 4, 2009 Sounds like the file should be 1) purged and 2) audited. Quote
PUNZY Posted December 6, 2009 Author Posted December 6, 2009 yes..i did that as...wel...long time and m doin it again n again...same thg... Quote
ReMark Posted December 6, 2009 Posted December 6, 2009 Is your version of 2008 current with its service pack? Quote
PUNZY Posted December 6, 2009 Author Posted December 6, 2009 Yes I Do Have It...and Nw..i Loaded 2010...with Full Licence...umm....and Service Pack....only This Drawing Is Giving Me Problem And Others Are Fine And Opeing Well... Quote
