toolroom Posted August 9, 2008 Posted August 9, 2008 Pls find attached drawing and help me to trim the parts extended over the intersected region. I am unable to use the Trim command ...Pls help out... Thank you... TRIM.dwg Quote
Cad64 Posted August 9, 2008 Posted August 9, 2008 One way to do it would be with Slice Planes. Refer to the attached drawing and post back if you have any questions. TRIM[1].dwg Quote
toolroom Posted August 10, 2008 Author Posted August 10, 2008 Ok I got it and tried also. But I think AutoCAD 2007 version should have some better options to do this easily. Anyways thank you for your effort. Quote
frunza_samuel Posted August 10, 2008 Posted August 10, 2008 if u ever do something like this again, i strongly recomand that u do your 2d first (with trim and anything else) and use the sweep command (it's much easyer even if u wanna round the edges, or other things) Quote
toolroom Posted August 11, 2008 Author Posted August 11, 2008 Sweep method really works good on it. Easier and fast. Thanks Quote
