Inserting PDF files into DWG file then e-mailing the file
Using AutoCAD LT 2010 I was able to successfully insert/attach my pdf files into my title-block and it looks great. However when I send the .dwg file to my client (he is using AutoCAD LT 2009 he can open the .dwg file but the .pdf files I attached was not visable, only my title block and lettering on the border.
Any ideas as to why this happened? Is there any way to set up the .dwg file so any .pdf files once attached will stay attached even when I e-mail it to someone using another version of AutoCAD LT?
thanks in advance for your help!
You need to use ETRANSMIT when sending drawing files. Check your Autocad Help files for information on this command.
Thanks, I tried using Etransmit but my client has AutoCAD LT 2009 which doesn't have the ability to attach pdf file into an dwg file. The dwg with pdfs attached looks great on my computer (LT 2010) but will he be able to see the pdf images in the dwg when he opens the dwg in LT 2009?
Maybe you should think about converting the pdf to tif or jpg and then insert that into the drawing instead of the pdf.
thanks for the tip, I'll try it.
Question: Do .jpg and .tif files perform differently when inserted into a dwg file than a .pdf file?
thanks,
You can't attach a pdf file into a dwg file, you have to convert a pdf to a tif.
I have been able to attach a pdf file into a dwg using LT 2010 but have problems when I send it to a client, the pdf files don't go along for the ride. I think I fixed that using Etransmit. However I'm trying to find out if a better option is to insert the document as a tiff file instead of a pdf so it really is attached to the dwg and not just referenced. My main concern is that the dwg travels well via e-mail with my inserted documents staying inserted so my client can open up the dwg and see my inserted documents with no problems.
LT 2010 may well be able to attach PDF's but since your client is using 2009 it cannot. I think that is what your problem is. Just convert the PDF to a JPG file and attach it. It will work the same way as attaching a PDF. Make sure your client has the JPG file in the same directory as the DWG file and AutoCad will be able to locate it just fine.
In 2010 you can attach a pdf using the PDFATTACH command. But previous versions do not have this capability.
Hmmm, I just tried that. I converted my pdf file (its a one page brochure) into a jpg. When I used the Ole Object insert button it did insert the jpg but all I see is a square box with an icon representing that this is a jpg but I don't see my document itself.
Thank you for clearing things up :D
