David Haddix Posted December 14, 2009 Posted December 14, 2009 Has anyone else had problems with placeing steel at the correct elevation in the 2010 MEP with An EastCoast add on? I am trying to place steel out of the tool palette and when I go into the properties manager I am unable to set a elevation before I place a piece of steel on the drawing. The dialog box for inputting the elevation will not allow for any information to be entered in before placement . Any Ideas? Quote
tzframpton Posted December 14, 2009 Posted December 14, 2009 This is a known issue as far as I'm concerned that is not related to EastCoast design to fab software. I've never been able to right-click and preset the elevation on steel or diffusers. I've even asked about this over the past two versions and some people can, some people can't. I haven't been able to figure it out. Quote
David Haddix Posted December 14, 2009 Author Posted December 14, 2009 Thanks for the info I will let you know if I come up with any solution Quote
